Move Node position in Xpresso menu [SOLVED]
On 16/11/2015 at 00:33, xxxxxxxx wrote:
Cinema 4D Version: R17
Platform: Windows ;
Language(s) : C++ ; XPRESSO ;---------
I created a C++ node-plugin (My_Node) ... by default it is on the menu: New Node -> Xpresso -> General -> My_Node ... How to move node (My_Node) in the menu: New Node -> My Group -> My_Node ?
http://forums.cgsociety.org/attachment.php?attachmentid=179117Example code get on forum
https://plugincafe.maxon.net/topic/3916/3386_baseobjects-and-objectlinkports&PID=13868#13868
On 16/11/2015 at 02:20, xxxxxxxx wrote:
please do not cross post on different forums or at least include a link to the other post. Thanks.
If you want to place your node in a custom class and group you have to add a custom class and group. A custom class is created like this:
static const String* GetGVClassName() { static String mygroup("My Class"); return &mygroup; } static BaseBitmap* GetGVClassIcon() { return nullptr; } static GV_OPCLASS_HANDLER myClass; myClass.class_id = CLASS_ID; myClass.GetName = GetGVClassName; myClass.GetIcon = GetGVClassIcon; GvRegisterOpClassType(&myClass, sizeof(myClass));
and a custom group is created like this:
static const String* GetGVGroupName(void) { static String mygroup("My Group"); return &mygroup; } static BaseBitmap* GetGVGroupIcon(void) { return nullptr; } static GV_OPGROUP_HANDLER myGroup; myGroup.group_id = GROUP_ID; myGroup.GetName = GetGVGroupName; myGroup.GetIcon = GetGVGroupIcon; GvRegisterOpGroupType(&myGroup, sizeof(myGroup));
Then you can use the IDs of the class and group when you register your plugin:
GvRegisterOperatorPlugin(1033969,"My Node",0,MyNode::Alloc,"gvmynode",0,CLASS_ID,GROUP_ID,0,bitmap);
best wishes,
Sebastian
On 17/11/2015 at 00:34, xxxxxxxx wrote:
Thanks.
