On 10/11/2015 at 14:53, xxxxxxxx wrote:
User Information: Cinema 4D Version: 16 Platform: Windows ; Language(s) : C++ ;
--------- Is it possible to send custom messages with NetSendData()? It seems like when I pass my own plugin ID, I always get MESSAGERESULT_UNKNOWN error and the message is not sent to the TR server. Small example:
struct NetRenderMsgVbGi { UInt size; Bool compute, wait; }; NetRenderBuffer msg, result; msg.id = MSG_NETRENDER_VB_GI; msg.job = vps->net->_renderJob->GetUuid(); msg.size = 0; msg.data = nullptr; MESSAGERESULT res = NetSendData( vps->net->_service, vps->net->_renderJob->GetServerUuid(), &msg, &result, vps->thread);
Thanks in advance, -Niklas
On 11/11/2015 at 02:30, xxxxxxxx wrote:
using R17 I have no problems using this code to send a message:
Int32* payload = NewObjClear(Int32, 1); *payload = 123; // prepare message NetRenderBuffer requestMessage; requestMessage.id = MSG_CUSTOM; requestMessage.job = data->_vps->net->_renderJob->GetUuid(); requestMessage.size = SIZEOF(Int32); requestMessage.data = payload; NetRenderBuffer requestResult; requestResult.id = MSG_CUSTOM; requestResult.job = data->_vps->net->_renderJob->GetUuid(); requestResult.size = 0; requestResult.data = nullptr; NetSendData(data->_vps->net->_service, data->_vps->net->_renderJob->GetServerUuid(), &requestMessage, &requestResult, data->_vps->thread); if(requestResult.data) { Int32* res = (Int32* )requestResult.data; GePrint("Got data from server: " + String::IntToString(*res)); }
best wishes, Sebastian
On 11/11/2015 at 03:29, xxxxxxxx wrote:
Hi Sebastian, thanks for the example. Seems like you really need a payload, it doesn't work without here in R16. Strangely, it works without payload for sending standard Net messages (eg. MSG_NETRENDER_BUCKET_INFO or ~_INDEX).
One thing I'm still wondering about though is about byte order. Won't there be issues with machines that communicate with this interface and use a different byte order?
Thanks, -Niklas
On 13/11/2015 at 00:25, xxxxxxxx wrote:
according to the developers, you are responsible for the endianess of the data chunk stored in NetRenderBuffer::data.
Best wishes, Sebastian
