On 07/11/2015 at 12:39, xxxxxxxx wrote:
Hi Guys, A Question on GetActiveObject? I use GetActiveObject to Select active object, that is in the Object List. Now when i use doc.GetActiveObject it dont work right. It separate them and not group them. This What *Console* Said: AssertionError: Found next objects. Please add them separately.
So I wanted It to generate with the selected object use choose and go under or become a child.
Code: def Generator_TAXILINE(self) :
#--| Generate and SET NAMES |--# #Generate Sweep taxi_sweep_Name = c4d.BaseObject(c4d.Osweep) taxi_sweep_Name.SetName("TaxiLine")
#User Custom TEMP TEMP_Name = self.linkBox.GetLink() TEMP_Name.SetName("TAXILINE_TEMP")
#Select User Custom Path selectedobject = doc.GetActiveObject() # <----| this Problem selectedobject.SetName("User-Custom-Path") #Insert Objects To LIST! doc.InsertObject(taxi_sweep_Name) doc.InsertObject(TEMP_Name) doc.InsertObject(selectedobject)
# Objects Order! parent = doc.SearchObject("TaxiLine") child_Temp = doc.SearchObject("User-Custom-Path") child_Temp.InsertUnder(parent) parent = doc.SearchObject("TaxiLine") child_Temp = doc.SearchObject("TAXILINE_TEMP") child_Temp.InsertUnder(parent) c4d.EventAdd() return True
#--|C.O.M.M.A.N.D.S|-------------------------------------------------------# def Command (self, id, msg) : if (id == GEN_BUTTON) : self.Generator_TAXILINE() #-------------------------------------------------------------------------------------------------# This what is happen when excute with doc.GetActiveObject() :
But If i use selectedobject = c4d.BaseObject(c4d.Osplinecircle) , IT WORKS FINE:
Help or Tip, Cheers, Ashton, sorry for my English guys.
On 07/11/2015 at 14:02, xxxxxxxx wrote:
In your code sample, you first select an object out of the existing tree: selectedobject = doc.GetActiveObject() and then you try to insert that somewhere else: doc.InsertObject(selectedobject)
I suppose C4D doesn't like that much. You should cut that object from the tree first, to isolate it. Then you can insert it somewhere else.
In your second sample, selectedobject = c4d.BaseObject(c4d.Osplinecircle) you create a new object, which naturally is not connected in the tree already, and insert that. This is uncritical, and therefore works.
On 07/11/2015 at 15:58, xxxxxxxx wrote:
thanks man IT WORKS BRO! CODE: def User_Custom_Path(self) : doc = c4d.documents.GetActiveDocument() selectedobject = doc.GetActiveObject() selectedobject.SetName("User-Custom-Path")
self.User_Custom_Path()
c4d.CallCommand(12298, 12298) # Model #--| Generate and SET NAMES |--# #Generate Sweep taxi_sweep_Name = self.linkBox2.GetLink().GetClone(c4d.COPYFLAGS_0) taxi_sweep_Name.SetName("TaxiLine") #User Custom TEMP TEMP_Name = self.linkBox.GetLink().GetClone(c4d.COPYFLAGS_0) TEMP_Name.SetName("TAXILINE_TEMP")
#Insert Objects To LIST! doc.InsertObject(taxi_sweep_Name) doc.InsertObject(TEMP_Name) #doc.InsertObject(selectedobject)
# Objects Oder! parent = doc.SearchObject("TaxiLine")
child_Temp2 = doc.SearchObject("TAXILINE_TEMP") child_Temp2.InsertUnder(parent)
c4d.EventAdd() return True #----------------------------------------------------------------------------------------# Thanks Cairyn Cheers, Ashton
