On 04/11/2015 at 10:00, xxxxxxxx wrote:
How can I call MODATA_FLAGS data? I'm trying to check with python effector is the clone visible or not.
def main() : md = mo.GeGetMoData(op) if md==None: return False cnt = md.GetCount() marr = md.GetArray(c4d.MODATA_MATRIX) farr = md.GetArray(c4d.MODATA_FLAGS) for i in xrange(cnt) : if (farr(c4d.MOGENFLAG_CLONE_ON)) : marr[i].Scale(1)
I get "TypeError: 'list' object is not callable"
On 04/11/2015 at 10:19, xxxxxxxx wrote:
if farr[i] == 1:
On 05/11/2015 at 01:22, xxxxxxxx wrote:
MODATA_FLAGS stores a bit mask. You find an example on how to edit the bits in the "Push Apart Effector" example. You also find symbols for the bits in the documentation.
A simple effector that hides every second clone could look like this:
md = mo.GeGetMoData(op) if md is None: return False farr = md.GetArray(c4d.MODATA_FLAGS) cnt = md.GetCount() for i in xrange(0, cnt) : if i % 2 == 1: farr[i] &= ~(c4d.MOGENFLAG_CLONE_ON) md.SetArray(c4d.MODATA_FLAGS, farr, True)
You find more information on bit manipulation in the Python Wiki.
best wishes, Sebastian
On 13/11/2015 at 09:37, xxxxxxxx wrote:
Hello aturtur,
was your question answered?
Best wishes, Sebastian
On 18/11/2015 at 11:43, xxxxxxxx wrote:
Yes, thank you!
