On 29/10/2015 at 13:44, xxxxxxxx wrote:
--------- Hi everyones,
There is a way to update or change during my tag execution the logo displayed in object manager?
Or maybe can I slide the current logo top to bottom or left to right ? In this way i'll have juste one res .tif image file to load and just slide during execution ?
Thanks in advance for any help on this.
On 30/10/2015 at 13:16, xxxxxxxx wrote:
you need to listen to MSG_GETCUSTOMICON in your tag's Message() function. The structure provided is GetCustomIconData. With this you can provide new icons or draw overlays.
On 31/10/2015 at 02:17, xxxxxxxx wrote:
Great !! I looking about it and I'll give you a feel back.
Thanks for all this informations
On 02/11/2015 at 03:53, xxxxxxxx wrote:
Hello Andreas. Thank a lot for your informations. But i can not make it work. I tried by multiples way but it seems not in my capability yet. Did you have a example in SDK ? Maybe a link with more information about this ?
last, in any other way maybe a code snippet. I know every ones belong here are very busy...
I can not make my bitmap slide. I tried with this...
if (type == MSG_GETCUSTOMICON){ GetCustomIconData().dat->x = 32; }
But as you probably know this throw me EXCEPTION ERROR because I guess I don't catch the right object. I Should instantiate something but i can't find it in SDK doc.
And I can not change my logo neither with this...
if (type == MSG_GETCUSTOMICON){ GetCustomIconData().dat->bmp = AutoBitmap("whatever.tif"); }
Same problem, i guess i should instance or catch something and after apply my GetCustomIconData() with additional problem : I not sure on the way to pass it a new data bitmap.
Thanks on any help on this. Everything else on my plugin seems to work. Soon I'll will asking for a complete review of my code if some are interested (I'm the one most interested!!)
On 02/11/2015 at 04:38, xxxxxxxx wrote:
one problem with your code is, that you are creating a new GetCustomIconData structure of your own. Instead you should use the one passed with the message (data parameter, which get's cast to the datatype delivered by the message type).
Here's a small Message() function as an example. Note that _iconBase and _iconOverlayed are two BaseBitmap pointers, that are initialized with two different icons during my startup code.
Bool MyPlugin::Message(GeListNode* node, Int32 type, void* data) { switch (type) { case MSG_GETCUSTOMICON: { GetCustomIconData* const gcid = static_cast<GetCustomIconData*>(data); // data pointer interpreted depending on message type if (!gcid || !gcid->dat || !_iconBase || !_iconOverlayed) break; BaseBitmap* const bmp = gcid->dat->bmp; if (bmp) { // There's already an icon setup, copy your icon into the existing BaseBitmap GeData d; node->GetParameter(TAG_ICON_OVERLAY, d, DESCFLAGS_GET_0); // TAG_ICON_OVERLAY is a bool parameter in my tag description if (d.GetBool()) _iconOverlayed->ScaleIt(bmp, 256, true, false); else _iconBase->ScaleIt(bmp, 256, true, false); } else { // No icon, yet, provide a new BaseBitmap gcid->dat->bmp = _iconBase; } gcid->filled = true; // tell message sender, that you provided a new icon break; } } return SUPER::Message(node, type, data); }
I hope, this helps.
On 02/11/2015 at 04:50, xxxxxxxx wrote:
Wahooo ! I'll give you feel back when I have understood this. Very interesting. Thanks
