Linear Workflow and Color returned from Shader
On 29/10/2015 at 10:44, xxxxxxxx wrote:
Cinema 4D Version:
Platform:
Language(s) :---------
Hi! In my shader, I'm reading a color user data field and return that color from Output(). The problem
is that this color looks different than what the color would look like if I used it directly in a Color shader
or the Color field of the Material channel. However, this is only when Linear Workflow is enabled.I've only found this topic and I tried calling InitRenderStruct::TransformColor() before I return the
color from ShaderData::Output(), but it did not change the result at all.return this->_irs->TransformColor(resultColor);
I don't know how to fix this, any ideas? Thanks in advance.
-N
On 29/10/2015 at 11:06, xxxxxxxx wrote:
Maybe the InitRenderStruct is not valid from InitRender() to FreeRender(). I saved the pointer to the
IRS passed to ShaderData::InitRender(). Now that I store a copy of the IRS, it works fine.INITRENDERRESULT Shader::InitRender(BaseShader* shader, const InitRenderStruct& irs) { this->_irs = irs; // ... } Vector Shader::Output(BaseShader* shader, ChannelData* cd) { // .. return this->_irs.TransformColor(color); }
On 30/10/2015 at 03:09, xxxxxxxx wrote:
a typical pattern to handle linear workflow is to save the transformation type in InitRender() and apply it in Output() using TransformColor(). Something like this:
// save color transformation information if (irs.linear_workflow && irs.document_colorprofile == DOCUMENT_COLORPROFILE_SRGB) _trans = COLORSPACETRANSFORMATION_SRGB_TO_LINEAR; else _trans = COLORSPACETRANSFORMATION_NONE; // ... // apply color transformation return TransformColor(result, _trans);
best wishes,
Sebastian
