On 27/10/2015 at 06:18, xxxxxxxx wrote:
BaseDocument has the functions GetData(), SetData() and GetDataInstance(), which can be used to access and modify project settings.
For example like this:
BaseContainer* settings = doc->GetSettingsInstance(DOCUMENTSETTINGS_DOCUMENT);
if (!settings)
return false;
settings->SetString(DOCUMENT_INFO_AUTHOR, "User");
EventAdd();
If it's a good idea to modify the project settings in your plugin's init, probably highly depends. I guess, some user's won't appreciate to get their project settings modified. And for example with an ObjectData plugin, why should it modify the project settings on every generated object? But that's just some thoughts, as I don't know your plugin or its type.
