On 22/10/2015 at 13:53, xxxxxxxx wrote:
User Information: Cinema 4D Version: R16 Platform: Windows ; Language(s) : C++ ;
--------- Hello.
I create a Material and in color channel i add an animated texture. How can i get the parameter values of this shader ? For example i need the values of Movie Start Frame and Movie End Frame.
Thank you very much
On 26/10/2015 at 03:20, xxxxxxxx wrote:
the parameters of a shader can be accessed like any other parameter with GetParamter(). You just just have to access the shader:
GeData data; mat->GetParameter(DescID(MATERIAL_COLOR_SHADER), data, DESCFLAGS_GET_0); BaseShader* shader = static_cast<BaseShader*>(data.GetLink(doc, Xbitmap)); if (!shader || !shader->IsInstanceOf(Xbitmap)) return false; shader->GetParameter(DescID(BITMAPSHADER_TIMING_FROM), data, DESCFLAGS_GET_0); const Int32 startTime = data.GetInt32(); shader->GetParameter(DescID(BITMAPSHADER_TIMING_TO), data, DESCFLAGS_GET_0); const Int32 endTime = data.GetInt32();
Please notice that the "Movie Start Frame" and "Movie End Frame" parameters are only set after the "Calculate" button was pressed.
best wishes, Sebastian
On 26/10/2015 at 06:03, xxxxxxxx wrote:
Thank you very much !
