On 22/10/2015 at 08:06, xxxxxxxx wrote:
Hi Guys,
Code line stops function from continuing on?
def The_Funtion(self, unit) :
c4d.CallCommand(100004820, 100004820) # Copy
#---------------| New Doc |-----------------# c4d.CallCommand(12094, 12094) # New
#----| GenerateProjectSettings |----# doc = c4d.documents.GetActiveDocument() unitScale = c4d.UnitScaleData() unitScale.SetUnitScale(1.0, unit)
bc = c4d.BaseContainer()
bc[c4d.DOCUMENT_DOCUNIT] = unitScale
bc[c4d.DOCUMENT_MINTIME] = c4d.BaseTime(self.GetLong(UI_FRAME_FROM_FBX), 30) bc[c4d.DOCUMENT_MAXTIME] = c4d.BaseTime(self.GetLong(UI_FRAME_TO_FBX), 30)
#---|Problem|----------------------------------------------------------------------------------------------------------# #--| When this 2 lines Excute, it stops the Function from going to Paste and It do what it suppose to do but don't continue | ----------# doc.GetLong(UI_FRAME_TO_FBX, bc[c4d.DOCUMENT_MINTIME].GetMinTime(doc.GetFps())) doc.GetLong(UI_FRAME_TO_FBX, bc[c4d.DOCUMENT_MAXTIME].GetMaxTime(doc.GetFps())) #----------------------------------------------------------------------------------------------------------------------# doc.SetDocumentData(c4d.DOCUMENTSETTINGS_DOCUMENT, bc)
#--------------- | Paste |-----------------# c4d.CallCommand(100004821, 100004821) # Paste
Help Plz or Tips, Ashton
On 22/10/2015 at 08:49, xxxxxxxx wrote:
Either
a) Include an SSCCE, or b) be more descriptive (did you check for errors in the console? what did you already try? etc.)
and please use the
[*/CODE] tags. -N
On 22/10/2015 at 09:56, xxxxxxxx wrote:
Hi NiklasR
This what Console Say: Traceback (most recent call last) : File "'SelectedObjectExporter.pyp'", line 1034, in Command File "'SelectedObjectExporter.pyp'", line 505, in Bake_Export_Takes_Funtion AttributeError: 'c4d.documents.BaseDocument' object has no attribute 'GetLong'
But if the 2 lines is not there it go through without a problem.
Help or Tips, Ashton
On 22/10/2015 at 10:37, xxxxxxxx wrote:
Hi Ashton If you search over c4d's pySDK only get
> BaseContainer. GetLong (Python method, in c4d.BaseContainer) > GeDialog. GetLong (Python method, in c4d.gui.GeDialog) > Seems, you need to retrieve data from bc(or dialog's widget), not doc
On 22/10/2015 at 10:42, xxxxxxxx wrote:
Originally posted by xxxxxxxx Hi NiklasR This what Console Say: Traceback (most recent call last) : File "'SelectedObjectExporter.pyp'", line 1034, in Command File "'SelectedObjectExporter.pyp'", line 505, in Bake_Export_Takes_Funtion AttributeError: 'c4d.documents.BaseDocument' object has no attribute 'GetLong' But if the 2 lines is not there it go through without a problem. Help or Tips, Ashton
Makes sense, no? Since the lines cause this error.
On 26/10/2015 at 18:27, xxxxxxxx wrote:
Hey guys notthing works, i give up, if yall have a answer or another tip plz tell me, I am already mad about this!, all i want this thing to do is set the Frame time line which is: you put your 30 to 40 in press export button and then, Set numbers in a new doc project Settings, Which happens! and then, min to max long that you drag it or set to, in the new project, and move on lol thats all i ask this thing to do. Code i post say it the tells it all.
On 27/10/2015 at 01:40, xxxxxxxx wrote:
Hi Your code is like small snippet for script manager and few lines are from script-log (like copy-paste, new, callCommand)
maybe need to something like
import c4d from c4d import gui, documents def main() : new = documents.BaseDocument() bc = c4d.BaseContainer() bc[c4d.DOCUMENT_FPS] = 30 bc[c4d.DOCUMENT_MINTIME] = c4d.BaseTime(0) # your data from your gui > c4d.BaseTime(self.GetLong(UI_FRAME_FROM_FBX), 30) bc[c4d.DOCUMENT_MAXTIME] = c4d.BaseTime(50, 30) # your data from your gui > c4d.BaseTime(self.GetLong(UI_FRAME_TO_FBX), 30) new.SetDocumentData(c4d.DOCUMENTSETTINGS_GENERAL, bc) c4d.documents.InsertBaseDocument(new) if __name__=='__main__': main()
