Interaction tag as plugin
  • On 21/10/2015 at 06:32, xxxxxxxx wrote:
    Hi
    I have an Interaction tag acting as a point constraint plugin. I've placed the code in the draw method, and that works in the view port except for a slight delay when dragging. But it doesn't work when rendering to the PV. Is that because the draw method isn't called when rendering to the PV?
    from c4d import gui
    #The tag has a user data field (link) for a point selection tag.
    def draw(bd) :
        #Get the number of points from the object that belongs to the tag in the user data field
        count = tag[c4d.ID_USERDATA,1].GetBaseSelect().GetCount()
        #Get the object that the tag belongs to
        pointObject = tag[c4d.ID_USERDATA,1].GetObject()
        #Convert the tag's data to a BaseSelect so we can do something with them
        PointS = tag[c4d.ID_USERDATA,1].GetBaseSelect()
        #Points in the tag will have an enabled state value in our BS instance
        pntArray = PointS.GetAll(tag[c4d.ID_USERDATA,1].GetObject().GetPointCount())
        #Calculate the global position of point
        newPos = pointObject.GetMg() * pointObject.GetPoint(pntArray.index(1))
        #Set up the matrix components
        off = newPos
        v1 = c4d.Vector( op.GetMg().v1 )
        v2 = c4d.Vector( op.GetMg().v2 )
        v3 = c4d.Vector( op.GetMg().v3 )
        #Build the Matrix
        objMatrix = c4d.Matrix(off,v1,v2,v3)
        #Set ops Matrix
        op.SetMg(objMatrix)
    Am i supposed to use the message method instead? If so, what message should the plugin listen for? Or is there an other way of approaching this with out making a full plugin.
    Any help appreciated
    -b
  • On 21/10/2015 at 06:38, xxxxxxxx wrote:
    Hi Bonsak,
    1. draw() is not called when rendering
    2. draw() is really only for drawing in the viewport, don't do any scene changes in it
    3. any reason you're not using a plain Python Tag?
    4. not sure, but if the Interaction Tag also supports a main() function, you should use that instead
    -N
  • On 21/10/2015 at 06:53, xxxxxxxx wrote:
    I see. I was planning for some added functionality with selected/unselected states etc but i can use a python tag for now. Seemed convenient with the Interaction tag.
    Thanks for the help.
    -b
  • On 22/10/2015 at 01:46, xxxxxxxx wrote:
    Hi Bonsak,
    I have a solution to this but it's not perfect. I've been using a python tag for the majority of my code, then throwing all of the data I need to draw into a global BaseContainer (or a stored object variable), then in the interaction tag, I use c4d.CallFunction to access it through a predefined function in the python tag. So essentially I'm only using the Interaction tag to draw stuff.
    It does have limited uses but it's a workflow that can be useful.
    Hope that helps,
    Adam
  • On 22/10/2015 at 01:51, xxxxxxxx wrote:
    Thanks Adam. I'll definitely try that.
    -b
  • On 27/10/2015 at 09:01, xxxxxxxx wrote:
    Originally posted by xxxxxxxx
    Hi Bonsak,
    Could you please post an example how you use the CallFunction.
    -Pim
  • On 27/10/2015 at 10:12, xxxxxxxx wrote:
    Hi Pim,
    This is an example of how I would move the data from a python tag to an interaction tag:
    First the python tag:
    # Set up the function that is going to be called from the other python object
    def GetMatrix() :
        if not matrix: return None
        bc = c4d.BaseContainer()
        bc.SetMatrix(0, matrix)
        return bc
    matrix = None
    def main() :
        obj = op.GetObject()
        global matrix
        #Assign the global variable with some data
        matrix = obj.GetMg()
    And then the Interaction tag:
    def draw(bd) :
        # The python object you want to call the function from
        py_op = op[c4d.ID_USERDATA,1]
        # Call the function from the python tag to get the BaseContainer
        bc = c4d.CallFunction(py_op, "GetMatrix")
        #Get the matrix
        matrix =  bc.GetMatrix(0)
        #Do stuff!
        print matrix
    Hope that's useful.
    Thanks,
    Adam
  • On 28/10/2015 at 05:56, xxxxxxxx wrote:
    Thanks, very useful.
    It seems like a very easy way to communicate between plugins!
    I am only confused about py_op.
    How / why does it point to the python object?
    The manual is not very clear to me:
    Parameters:|
    • op  ([BaseList2D](file:///D:/sdk%20manuals/Python%20R16sdk%20manual/help/modules/c4d/C4DAtom/GeListNode/BaseList2D/index.html#c4d.BaseList2D)) – The object to search the function within its script.
    _<_t_>_
    -Pim
  • On 28/10/2015 at 06:15, xxxxxxxx wrote:
    The 'op' variable by default in the interaction tag refers to the object the tag is on and not the tag itself.
    The interaction tag I was using was on a Null object. I set a UserData link box onto the Null and put the PythonTag into it as an easy way of referencing it.
    Hence :
    #op is the Null object
    #ID_USERDATA,1 being the LinkBox with the PythonTag referenced to it.
    I guess I could have just used op.GetFirstTag() too, as the PythonTag was first on the Null object.
  • On 28/10/2015 at 09:04, xxxxxxxx wrote:
    Ok, clear now.
    If I want to communicate with another plugin, the op will be that plugin.
    -Pim
  • On 28/10/2015 at 09:08, xxxxxxxx wrote:
    I think that he CallFunction command might unfortunately be limited to certain objects, it looks like plugins are not included.
    From the documentation:
    "This works for both Python and C.O.F.F.E.E. scripting tags, effectors, XPresso nodes, Interaction tags and also for Python generators."
  • On 28/10/2015 at 09:21, xxxxxxxx wrote:
    I agree,it is not very clear.
    As I read it, it should also be possible for plugins.
    A plugin is also an (scripting) object.
    Perhaps Maxon can clarify?
    -Pim
  • On 29/10/2015 at 10:35, xxxxxxxx wrote:
    Hello everyone,
    I'm sorry, but a Python plugin is not a scripting object. CallFunction() can not be used to communicate with a Python plugin.
    CallFunction() only works for NodeData derived things, which already provide a scripting option (like Python tag, Interaction tag, Python Generator,...).
  • On 29/10/2015 at 12:33, xxxxxxxx wrote:
    Thanks,that clarifies it for me.
    -Pim
