Layer Manager [SOLVED]
  • On 14/10/2015 at 14:40, xxxxxxxx wrote:
    Cinema 4D Version:   16
    Platform:   Windows  ;
    I want to read out all Layers from the Layer Manager. Also I want to add new layers, remove and rename. I found the LayerSet in the SDK: https://developers.maxon.net/docs/Cinema4DCPPSDK/html/class_layer_set.html#afc9ab69643027a912262c285c59e2be8
    But I don't know how to use it? Does someone has an example for me?
    thanks
  • On 14/10/2015 at 15:41, xxxxxxxx wrote:
    No code but LayerData is where you want to begin.  You can get the root layer (a list head) of the Document using BaseDocument::GetLayerObjectRoot().  Search here for GetLayerObjectRoot for some topics and code.
  • On 14/10/2015 at 22:02, xxxxxxxx wrote:
    Thank You,
    I figured out how it works:
          GeListHead* layerList = NULL;
          layerList = doc->GetLayerObjectRoot();
          LayerObject *layer = (LayerObject* )layerList->GetFirst();   //Get the first layer
          const LayerData *data = layer->GetLayerData(doc, FALSE);    //Get the layer's container
          while (layer) {
              GePrint(layer->GetName());
              layer = layer->GetNext();
  • On 15/10/2015 at 01:14, xxxxxxxx wrote:
    Layers are not just stored in a list but actually in a tree. So to get all layers you also need to check the child layers with GetDown().
    Best wishes,
    Sebastian
