On 13/10/2015 at 03:03, xxxxxxxx wrote:
Hi all,
This might be very obvious, but I couldn't find out how to do this. I need to read out the OBJ import settings from the preferences pane. Anyone know how?
Greets! HW
On 14/10/2015 at 10:16, xxxxxxxx wrote:
in our GitHub repository you can find examples for OBJ im-/export. Basically it works the same for all im-/exporters (and as demonstrated for OBJ in above examples) :
The IDs to get the settings from the BaseContainer are easiest to find, via dragging the desired option from the Im-/Exporter dialog into the console.
One more note: The OBJ im-/exporter changed from R16 to R17. In the above mentioned examples you see the IDs for R17 (export: 1030178, import: 1030177). In R16 you can use c4d.FORMAT_OBJEXPORT and c4d.c4d.FORMAT_OBJIMPORT instead. The change of IDs unfortunately slipped through when R17 got released.
On 21/10/2015 at 03:22, xxxxxxxx wrote:
Sorry for the late response, but thanks for the info!
