On 08/10/2015 at 10:02, xxxxxxxx wrote:
Hi Guys, How can fix this i want to GET and Copy the object that is in side the linkbox plz.
self.lnk_source = self.AddCustomGui(UI_LNK_SOURCE, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT, 50, 10, self.rootLinkBaseContainer)
if id == Verify_fbxBT:
doc = c4d.documents.GetActiveDocument() fps = doc.GetFps() #-----------| Copy Object From LinkBox |---------------#
#How I fix this! get it to Copy what is inside the linkbox
self.lnk_source.GetLink() doc.GetActiveObjects(self.lnk_source.GetLink())
c4d.CallCommand(12094, 12094) # New
#----| GenerateProjectSettings |----#
doc = c4d.documents.GetActiveDocument() unitScale = c4d.UnitScaleData() unitScale.SetUnitScale(1.0,c4d.DOCUMENT_UNIT_M) bc = c4d.BaseContainer() bc[c4d.DOCUMENT_DOCUNIT] = unitScale doc[c4d.DOCUMENT_MINTIME] = c4d.BaseTime(self.GetLong(UI_FRAME_FROM), 30) doc[ c4d.DOCUMENT_MAXTIME] = c4d.BaseTime(self.GetLong(UI_FRAME_TO), 30) doc.SetDocumentData(c4d. DOCUMENTSETTINGS_DOCUMENT, bc)
c4d.CallCommand(100004821, 100004821) # Paste
#----| EXCUTE FORMAT |----# c4d.CallCommand(60000, 9)
#----| KillDocument |----# doc = c4d.documents.GetActiveDocument() c4d.documents.KillDocument(doc)
cheers, Ashton
On 08/10/2015 at 13:48, xxxxxxxx wrote:
#how i fix this! get it to Copy what is in thelink box > self.lnk_source.GetLink() > doc.GetActiveObjects(self.lnk_source.GetLink())
What about:
myCopy=self.Ink_source.GetLink().GetClone(c4d.COPYFLAGS_0)
On 08/10/2015 at 14:28, xxxxxxxx wrote:
That did not work bro
On 09/10/2015 at 00:40, xxxxxxxx wrote:
to resolve the link of the LinkBoxGui one has to hand over the document containing the object to GetLink() as an argument. Something like this:
obj = linkBox.GetLink(c4d.documents.GetActiveDocument())
best wishes, Sebastian
On 09/10/2015 at 05:03, xxxxxxxx wrote:
hey still dont work and Plugin did not Show up when i Restart C4d lol But any other tip this how it looks now. And if you have a Documentation on this or More of Example doing this type of thing Plz Send it.
if id == Verify_fbxBT: doc = c4d.documents.GetActiveDocument() fps = doc.GetFps()
#-------| Get Obj and Copy Obj From LinkBox |--------# This one Section is Killing me Guys!
source = self.Ink_source.GetLink(c4d.documents.GetActiveDocument())) c4d.CallCommand(100004820, 100004820) # Copy
#---------------| New Doc |-----------------# c4d.CallCommand(12094, 12094) # New
#----| GenerateProjectSettings |----# doc = c4d.documents.GetActiveDocument() unitScale = c4d.UnitScaleData() unitScale.SetUnitScale(1.0,c4d.DOCUMENT_UNIT_M) bc = c4d.BaseContainer() bc[c4d.DOCUMENT_DOCUNIT] = unitScale doc[c4d.DOCUMENT_MINTIME] = c4d.BaseTime(self.GetLong(UI_FRAME_FROM), 30) doc[ c4d.DOCUMENT_MAXTIME] = c4d.BaseTime(self.GetLong(UI_FRAME_TO), 30) doc.SetDocumentData(c4d. DOCUMENTSETTINGS_DOCUMENT, bc)
#--------------- | Paste |-----------------# c4d.CallCommand(100004821, 100004821) # Paste
On 09/10/2015 at 08:50, xxxxxxxx wrote:
when the plugin does not show up this properly means that there is some syntax error in your code. Do you get any error message in the console?
Also, in your code you don't do anything with the "source" variable.
Best wishes, Sebastian
On 09/10/2015 at 11:12, xxxxxxxx wrote:
I got it back up and running bro it was that line bro, so here is the Command Section, plz tell me what I am doing wrong plz?
#-----| T.H.E__C.O.M.M.A.N.D.S__F.U.N.C.T.I.O.N.S |--------------------------------------------------# def Command(self, id, msg) :
print "ID: ", id if (id == 1021) : #<-------------------------ADD Layout self.LayoutFlushGroup(id=1030) self.newfieldindex += 1
for newid in range(1,self.newfieldindex+1) : #newid = self.newfieldindex id = newid + 1030 fieldname = "Take Slot " + str(newid)
self.AddStaticText(id=id, flags=c4d.BFH_CENTER, initw=250, name=fieldname, borderstyle=c4d.BORDER_NONE) self.AddSeparatorH(150, flags=c4d.BFH_SCALEFIT) self.GroupBegin(20001, c4d.BFH_SCALEFIT, 2, 0, "") doc = c4d.documents.GetActiveDocument() self.rootLinkBaseContainer = c4d.BaseContainer() self.AddStaticText(id=0, flags=c4d.BFH_MASK, initw=90, name="File Name:", borderstyle=c4d.BORDER_NONE) self.AddEditText(1000, c4d.BFH_SCALEFIT, 100, 0) self.AddStaticText(id=0, flags=c4d.BFH_MASK, initw=150, name="Source Object:", borderstyle=c4d.BORDER_NONE) self.lnk_source = self.AddCustomGui(UI_LNK_SOURCE, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT, 50, 10, self.rootLinkBaseContainer) self.GroupEnd() if (id == 1022) : #remove bottom GUI field self.LayoutFlushGroup(id=1030) self.newfieldindex -= 1 if (self.newfieldindex < 0) : self.newfieldindex = 0
for newid in range(1,self.newfieldindex+1) : #newid = self.newfieldindex id = newid + newid fieldname = "Take Slot " + str(newid)
self.AddStaticText(id=id, flags=c4d.BFH_CENTER, initw=250, name=fieldname, borderstyle=c4d.BORDER_NONE) self.AddSeparatorH(150, flags=c4d.BFH_SCALEFIT) self.GroupBegin(20001, c4d.BFH_SCALEFIT, 2, 0, "") doc = c4d.documents.GetActiveDocument() self.rootLinkBaseContainer = c4d.BaseContainer() self.AddStaticText(id=0, flags=c4d.BFH_MASK, initw=90, name="File Name:", borderstyle=c4d.BORDER_NONE) self.AddEditText(1000, c4d.BFH_SCALEFIT, 100, 0) self.AddStaticText(id=0, flags=c4d.BFH_MASK, initw=150, name="Source Object:", borderstyle=c4d.BORDER_NONE) self.lnk_source = self.AddCustomGui(UI_LNK_SOURCE, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT, 50, 10, self.rootLinkBaseContainer) self.GroupEnd() #Group with 4 columns self.GroupBegin(20001, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 4, 0, "Animation Frame Timeline") self.GroupBorder(c4d.BORDER_GROUP_IN) self.AddStaticText(0, c4d.BFH_LEFT, 0, 0, "Start:", 0) self.AddEditNumberArrows(UI_FRAME_FROM, c4d.BFH_SCALEFIT, 50, 15) self.AddStaticText(0, c4d.BFH_LEFT, 0, 0, "End:", 0) self.AddEditNumberArrows(UI_FRAME_TO, c4d.BFH_SCALEFIT, 50, 15) self.GroupEnd() self.AddButton(1022, c4d.BFH_RIGHT, initw=160, name="Remove Take Slot") self.GroupBegin(id=1044, flags=c4d.BFH_FIT, cols=1) self.AddSeparatorH(150, flags=c4d.BFH_SCALEFIT) self.GroupEnd() doc = c4d.documents.GetActiveDocument() self.SetLong(UI_FRAME_FROM, doc[c4d.DOCUMENT_MINTIME].GetFrame(doc.GetFps())) self.SetLong(UI_FRAME_TO, doc[c4d.DOCUMENT_MAXTIME].GetFrame(doc.GetFps()))
self.LayoutChanged(id=1030) return True
if id == Verify_fbx_Close_BT: self.Close()
if id == Verify_fbxBT: #<-----This is the (Bake & Export Takes) Button #gui.MessageDialog("This feature is Still IN Development!", c4d.GEMB_OK) doc = c4d.documents.GetActiveDocument() fps = doc.GetFps()
#-------| GET OBJECT And COPY OBJECT From LinkBox |--------#
This is the Problem?
UI_LNK_SOURCE = self.Ink_source.GetLink(c4d.documents.GetActiveDocument(doc))) c4d.CallCommand(100004820, 100004820) # Copy
return True #-------------------------------------------| END OF F.U.N.C.T.I.O.N.S |------------------------------------------# PLZ HELP, Ashton
On 16/10/2015 at 09:48, xxxxxxxx wrote:
GetActiveDocument() does not take any argument. Please consult the documentation to learn details like this.
