cdl64 not loaded
On 14/09/2015 at 14:53, xxxxxxxx wrote:
Cinema 4D Version: R16
Platform: Windows ;
Hello!I have created a plugin that runs in my system as it supposed to (using Visual Studio 2013).
It creates a folder MyPlugin along with the corresponding menu item.
Everything works fine.Sometimes though, when i transfer the plugin folder to other PCs, it is not loaded in Cinema4D.
Even when i try to run Cinema4D using visual studio (via cinema4dSDK) i get the messages:'CINEMA 4D.exe' (Win32) : Loaded '<path>/my_plugin.cdl64'. Cannot find or open the PDB file.
'CINEMA 4D.exe' (Win32) : Unloaded '<path>/my_plugin.cdl64'Why does it unload the plugin?
Thank you.
On 15/09/2015 at 03:43, xxxxxxxx wrote:
you need to recompile it, I guess you are doing it in debug mode, in release mode you won't encounter this problem.
On 15/09/2015 at 04:34, xxxxxxxx wrote:
Hello.
I build it in release mode and then i install it in different PCs.
Thnx.
On 15/09/2015 at 05:53, xxxxxxxx wrote:
my first bet would be the version of Cinema 4D (actually the API_VERSION). If the plugin id build on a higher version than the version trying to load the plugin, it will fail.
Usually you can expect your plugins to be upward compatible. For example, I still have plugins running in R17, that have been built against R13. The other way around won't work.
So, this would be the first thing to check.
On 15/09/2015 at 06:24, xxxxxxxx wrote:
Hello !
The plugin is built using the R16 Api.
It also runs in R15 and R17 but it doesnt in R16.
On 15/09/2015 at 06:34, xxxxxxxx wrote:
Please check also the minor version. For example there was a problem within R16, which made it necessary to bump the API_VERSION during R16.
On 16/09/2015 at 23:54, xxxxxxxx wrote:
I have the same issue.
I compiled on 16.59 and it runs.
It also runs on 16.050 (Build RB131856).
I will check with the customer which version he runs.For what versions will it fail?
On 17/09/2015 at 00:33, xxxxxxxx wrote:
Hello.
Thank you very much for your answer.
Updating Cinema4D version solves the problem.thnx.
