On 27/08/2015 at 06:20, xxxxxxxx wrote:
i read a directory via this function:
def listdir(path) : dd = [] files = (file for file in os.listdir(path) if os.path.isfile(os.path.join(path, file))) for item in files: dd.append(item) return dd
if there an ü ä ö in the filename the string got cuttet like this: 13_00_M_Jonas.tif < 13_00_Müller_Jonas.tif
On 28/08/2015 at 01:34, xxxxxxxx wrote:
The problem you're having isn't related to the Cinema Python API but to the string encoding having german characters in the filenames. You should in this case encode/decode the filename strings. See this thread for more information.
