GeUserArea keyboard focus
  • On 23/08/2015 at 01:52, xxxxxxxx wrote:
    Cinema 4D Version:   15+
    Platform:   Windows  ;
    I can't get focus properly on keyboard, somehow to get focus I need to do a click first with mouse, then it can read keyboard ONCE!!, I need it to get the keyboard keys anytime "not just once, or by a refreshing mouse click"
    Bool SNodeUserArea::InputEvent(const BaseContainer& msg)
    	Int32 dev = msg.GetInt32(BFM_INPUT_DEVICE);
    	Int32 chn = msg.GetInt32(BFM_INPUT_CHANNEL);
    	if (dev == BFM_INPUT_KEYBOARD)
    		GePrint("key pressed");//prints only if I press mouse before keyboard...
    		if(chn == KEY_DELETE)
    			BaseContainer actionk(BFM_ACTION);
    			actionk.SetInt32(BFM_ACTION_ID, GetId());
    			actionk.SetInt32(BFM_ACTION_VALUE, 0);
    			actionk.SetInt32(BFM_ACTION_UPDATE, true);
    			removeSelectedNodes();
    			removeSelectedWires();
    			InvokeCommandCall(GetDialog(), COMMANDMSG_VALUECHANGED);
    			SendParentMessage(actionk);
    			return true;
    	else if (dev == BFM_INPUT_MOUSE)
            return false;
  • On 24/08/2015 at 01:59, xxxxxxxx wrote:
    what exactly are you doing in InvokeCommandCall() and what consequences does SendParentMessage() have? Do you also loose the focus if you don't call InvokeCommandCall()?
    Best wishes,
    Sebastian
  • On 24/08/2015 at 02:27, xxxxxxxx wrote:
    here is what I do:
    static Bool InvokeCommandCall(GeDialog* dialog, Int32 id) {
        BaseContainer actionmsg(BFM_ACTION), actionresult;
        actionmsg.SetInt32(BFM_ACTION_ID, id);
        return dialog->Message(actionmsg, actionresult);
    in iCustomGui subclass:
        virtual Bool Command(Int32 id, const BaseContainer& msg) {
            if (id == COMMANDMSG_VALUECHANGED) {
                SendValueChanged(this, msg);
            return TRUE;
    static Bool SendValueChanged(iCustomGui* dlg, BaseContainer msg) {
        msg.SetInt32(BFM_ACTION_ID, dlg->GetId());
        msg.RemoveData(BFM_ACTION_VALUE);
        msg.SetData(BFM_ACTION_VALUE, dlg->GetData().GetValue());
        //GePrint("just msg " + String::IntToString((static_cast<iSnodeDataType*> (msg.GetData(BFM_ACTION_VALUE).GetCustomDataType(SEVENPHOTONS_NODE_CUSTOMDATATYPE)))->count));
    	return dlg->SendParentMessage(msg);
    which is simply updating my CustomDataType members, so if user interacts with GeUserArea,  InvokeCommandCall()  is the update function.
    if I remove  InvokeCommandCall()  , there is a delay, but it works without a problem, what should I do?
  • On 24/08/2015 at 09:13, xxxxxxxx wrote:
    why are you sending a message in InvokeCommandCall() and then again with SendParentMessage()? Typically one uses SendParentMessage() to inform the parent dialog that something changed.  See the example on GitHub.
    Best wishes,
    Sebastian
  • On 24/08/2015 at 10:39, xxxxxxxx wrote:
    I see, but the problem remains "I removed all calls to SendParentMessage(), all calls now are InvokeCommandCall()"
  • On 25/08/2015 at 00:07, xxxxxxxx wrote:
    actually I would have suggested to remove that InvokeCommandCall() stuff and just send the SendParentMessage() to react accordingly when you catch that message.
    Best wishes,
    Sebastian
  • On 25/08/2015 at 04:18, xxxxxxxx wrote:
    I will try, will reply soon with an update if it worked or not, thanks Sebastian.
  • On 28/12/2015 at 18:39, xxxxxxxx wrote:
    Hi Sebastian,
    I know that was a little old, but I reworked the code and did many tests to see where the problem is.
    now what I can confirm: (attached a piece of the code..)
    	GePrint("any event!!");
    		GePrint("any key is pressed");
    			if (!selection)
    				return true;
    			//InvokeCommandCall(GetDialog(), COMMANDMSG_VALUECHANGED, actionk);
    			return true;
    the problem is:
    after a mouse click "for example selecting a node in my userarea" , this changes the data of my CustomDataType, once this is done, the focus is gone!
    so next keyboard hit is missing "the whole InputEvent() is not called at all!" , so I have to click again.
    I also tested it with your example, your example works fine!, the only difference that I see is: in many cases I may send multiple parent messages... "is this a problem?"
    though I hacked around it, not sure if this is fine or not "you may tell " , I set:
    action.SetInt32(BFM_ACTION_UPDATE, true);
    this forced it to work! , so if this is fine you can consider this solved or suggest a better alternative
  • On 30/12/2015 at 14:33, xxxxxxxx wrote:
    ok I found a pitfall!!, action.SetInt32(BFM_ACTION_UPDATE, true); actually updates immediatly BUT ignores the data change update "so the GeUserArea updates, but the internal data doesn't get a refresh "as this user area can be seen in multiple object managers, I see it only updating in 1 location when  action.SetInt32(BFM_ACTION_UPDATE, true); is active!"
    on the other hand without this line, it got the keyboard delay focus, ideas?
  • On 31/12/2015 at 04:55, xxxxxxxx wrote:
    Hi Mohamed,
    Sorry for my late reply.
    Sebastian will be back next week and I'm sure he'll be able to give you feedback and ideas for your problem.
  • On 04/01/2016 at 02:07, xxxxxxxx wrote:
    Hello Mohamed,
    your last posts are a little bit confusing. Can you post your current code of all relevant classes and functions?
    Best wishes,
    Sebastian
  • On 04/01/2016 at 04:44, xxxxxxxx wrote:
    Hi Sebastian,
    I guess the functions are getting delayed due to heavy processing "when the MatPreview is rendering the this problem happens!".
    so I guess it is a wait for event loop that get ignored due to thread being busy in rendering.
    but the problem as I posted, and the code is quite complex!! "more than 7k lines../+ I can't strip it ".
  • On 04/01/2016 at 09:10, xxxxxxxx wrote:
    I do not understand how material preview rendering is related to this thread. Without more specific information I don't think it is possible to give more help.
    Best wishes,
    Sebastian
  • On 05/01/2016 at 05:05, xxxxxxxx wrote:
    He Sebastian,
    it is a long story "this GeUserArea is a custom gui for a custom data type inside my MaterialData plugin".
    but I tested when rendering is off too, it didn't work for unknown reason, I guess I will accept the result anyway.
    you can consider this solved/closed.
