On 20/08/2015 at 18:07, xxxxxxxx wrote:
Hello, I'm trying to write a script for to align letters according to their bounding box xsize. (Like in arrange command but depending on previous objects xsize) For example each polygonal letters A,B,C have different xsizes. I want something like polygonal kerning:) Problem: https://www.dropbox.com/s/betsyjksb1y6zm3/alphabet0.jpg?dl=0
How it should look like (more or less) : https://www.dropbox.com/s/pdjt4cp3f2t5vl5/alphabet1.jpg?dl=0
And my testing scene : https://www.dropbox.com/s/lb34jrvh30q8691/scene_for_testing_script.c4d?dl=0
My code is : (Note: All objects are centered to object axis, zero PSR and they are under a null as shown in the image above.) I tried to assign objects into an array. But I stock around positioning them. Please show me an example or check my script and note that I'm a beginner. (P.S. I should solve that issue with Python Script because it will be another part of my main script...) Thanks a lot.
import c4d from c4d import Vector
def find_objects(op, objectarray) : objectarray.append(op) for child in op.GetChildren() : find_objects(child, objectarray) def getsize(op,size) : size = op.GetRad()*2 position = op.GetMp() + op.GetAbsPos() xsize = int(size.x) xsizearray.append((xsize))
def main() : global xsizearray objects = [] size = [] xsizearray = [] position = [] xpos = [] for obj in doc.GetObjects() : find_objects(obj, objects) count = len(objects) for i in xrange (count) : getsize(objects _,size) print xsizearray _ objects _.SetRelPos(c4d.Vector(xsizearray _,0,0)) c4d.EventAdd() main()
On 21/08/2015 at 02:13, xxxxxxxx wrote:
I guess you would have to check if two letters collide and move them around until they don't collide anymore. In C++ there is the GeColliderEngine available that might be used. Currently this engine is not avialable in Python, so you have to develop an own solution.
Best wishes, Sebastian
On 21/08/2015 at 03:15, xxxxxxxx wrote:
Hello, Thank you for an answer, What I need is something basic actually, those letters are polygons I'm calling them from specific library and merge them into a scene. Basically following letters should be located next to previous letter depending on its bounding box xsize.
I tried something, but it's moving all letters ( Sorry I'm a beginner:) ) Any advice please?
def find_objects(op, objectarray) : objectarray.append(op) for child in op.GetChildren() : find_objects(child, objectarray) def getsize(op,size) : global xsize size = op.GetRad()*2 position = op.GetMp() + op.GetAbsPos() xsize = int(size.x*2) xsizearray.append((xsize)) def move(op,sizex) : pos = c4d.Vector(sizex,0, 0) op.SetRelPos(pos) def main() : global xsizearray objects = [] size = [] xsizearray = [] for obj in doc.GetObjects() : find_objects(obj, objects) count = len(objects) for i in xrange (count) : getsize(objects _,size) move(objects _,xsizearray _) print ("Count of Objects " + str(count) ) print ("Objects' X Size Valuess " + str(xsizearray) ) c4d.EventAdd() main()
On 21/08/2015 at 08:37, xxxxxxxx wrote:
it seems that when you call "getsize" and "move" you hand over all objects and not a single object.
On 24/08/2015 at 16:41, xxxxxxxx wrote:
I got you a working example at c4dcafe, as a reply to your post there, grasycho.
On 24/08/2015 at 23:53, xxxxxxxx wrote:
Thank you very much Rui:)
