On 16/12/2002 at 17:20, xxxxxxxx wrote:
I'd like to have a texture that can be controlled in xpresso that simply is a keyframable/controllable version of the standard image options from the material manager (you know the one where you tel it to calculate the length of a movie clip that you might have loaded etc).
the reason for this is that i would like to be able to control playback of movies in textures using xpresso. this would save having to make multiple textures and using condition nodes to control which "frame" is on the current object.
i would like to simply be able to change the value for the image/movie (it's file link) and also the current frame, using xpresso.
On 26/06/2013 at 12:24, xxxxxxxx wrote:
YES !! And Can control animation start of movie texture in xpresso
