Range Mapper Node GetInPort [SOLVED]
On 20/08/2015 at 06:57, xxxxxxxx wrote:
Cinema 4D Version:   R16
Platform:      Mac OSX  ;
I'm creating an XPresso file with a Range Mapper Node.
However, getting the Input Inport gives me problems.
GvPort* rangemapperInputInPort = rangeMapperNode->GetInPort(0);
This doesn't give me the Inport.
Yet:
GvPort* rangeMapperOutputOutPort = rangeMapperNode->GetOutPort(0);
gives me the Outport.
How should I get the input port??
Thanks in advance for your help and time!
On 21/08/2015 at 04:44, xxxxxxxx wrote:
Hi Casimir,
I quickly tested this using a Python script and it simply worked as expected. Nothing special needed. As Python in the end makes use of the C++ API, I have no reason to believe it's not working in C++.
Can you perhaps provide me with some more code, to check what is going on on your side?
On 21/08/2015 at 04:54, xxxxxxxx wrote:
Hi Andreas,
Here is some more code:
XPressoTag* footGoalXPressoTag;
  if (doFrontSide)
      if (doLeftGoalSide)
          footGoalXPressoTag = static_cast<XPressoTag*>(frontLeftFootGoal->MakeTag(Texpresso, NULL));
          if (!footGoalXPressoTag) return false;
          if (doLeftSide)
              footGoalXPressoTag->SetName("Left_Front_Left_Foot_Goal_XPresso_Tag");
          else
              footGoalXPressoTag->SetName("Right_Front_Left_Foot_Goal_XPresso_Tag");
      else
          footGoalXPressoTag = static_cast<XPressoTag*>(frontRightFootGoal->MakeTag(Texpresso, NULL));
          if (doLeftSide)
              footGoalXPressoTag->SetName("Left_Front_Right_Foot_Goal_XPresso_Tag");
          else
              footGoalXPressoTag->SetName("Right_Front_Right_Foot_Goal_XPresso_Tag");
  else
      if (doLeftGoalSide)
          footGoalXPressoTag = static_cast<XPressoTag*>(backLeftFootGoal->MakeTag(Texpresso, NULL));
          if (doLeftSide)
              footGoalXPressoTag->SetName("Left_Back_Left_Foot_Goal_XPresso_Tag");
          else
              footGoalXPressoTag->SetName("Right_Back_Left_Foot_Goal_XPresso_Tag");
      else
          footGoalXPressoTag = static_cast<XPressoTag*>(backRightFootGoal->MakeTag(Texpresso, NULL));
          if (doLeftSide)
              footGoalXPressoTag->SetName("Left_Back_Right_Foot_Goal_XPresso_Tag");
          else
              footGoalXPressoTag->SetName("Right_Back_Right_Foot_Goal_XPresso_Tag");
  GeData footGoalXPressoData;
  if (footGoalXPressoTag->GetParameter(DescLevel(EXPRESSION_PRIORITY), footGoalXPressoData, DESCFLAGS_GET_0))
      PriorityData* pd = (PriorityData* )footGoalXPressoData.GetCustomDataType(CUSTOMGUI_PRIORITY_DATA);
      if (pd)
          pd->SetPriorityValue(PRIORITYVALUE_MODE, CYCLE_GENERATORS);
          pd->SetPriorityValue(PRIORITYVALUE_PRIORITY, GeData(4));
      footGoalXPressoTag->SetParameter(DescLevel(EXPRESSION_PRIORITY), footGoalXPressoData, DESCFLAGS_SET_0);
  GvNodeMaster* footGoalNodeMaster = footGoalXPressoTag->GetNodeMaster();
  if (footGoalNodeMaster)
      // Create the Range Mapper Node
      GvNode* rangeMapperNode = footGoalNodeMaster->CreateNode(footGoalNodeMaster->GetRoot(), ID_OPERATOR_RANGEMAPPER, nullptr, 130, 0);
      if (!rangeMapperNode) return false;
      rangeMapperNode->SetParameter(GV_RANGEMAPPER_CLAMP_UPPER, GeData(true), DESCFLAGS_SET_0);
      rangeMapperNode->SetParameter(GV_RANGEMAPPER_CLAMP_LOWER, GeData(true), DESCFLAGS_SET_0);
      GvPort* rangeMapperInputInPort = rangeMapperNode->GetPort(GV_RANGEMAPPER_INPUT_USER); // Doesn't work, regardless if I use GetPort or GetInPort
      if (rangeMapperInputInPort) return false;
      GvPort* rangeMapperOutputOutPort = rangeMapperNode->GetOutPort(GV_RANGEMAPPER_OUTPUT_USER);
      if (!rangeMapperOutputOutPort) return false;
      GvPort* rangeMapperInputUpperInPort = rangeMapperNode->AddPort(GV_PORT_INPUT, GV_RANGEMAPPER_RANGE12);
      if (!rangeMapperInputUpperInPort) return false;
      GvPort* rangeMapperOutputUpperInPort = rangeMapperNode->AddPort(GV_PORT_INPUT, GV_RANGEMAPPER_RANGE22);
      if (!rangeMapperOutputUpperInPort) return false;
      GvPort* rangeMapperInputLowerInPort = rangeMapperNode->AddPort(GV_PORT_INPUT, GV_RANGEMAPPER_RANGE11);
      if (!rangeMapperInputLowerInPort) return false;
      GvPort* rangeMapperOutputLowerInPort = rangeMapperNode->AddPort(GV_PORT_INPUT, GV_RANGEMAPPER_RANGE21);
      if (!rangeMapperOutputLowerInPort) return false;
I hope this helps finding the problem.
Thanks for your help and time!!
On 21/08/2015 at 08:48, xxxxxxxx wrote:
Hi Casimir,
pssst, I won't tell anybody, but please have a look at the error check after GetPort().
On 21/08/2015 at 08:58, xxxxxxxx wrote:
Hi Andreas,
Hahahaha, like you said in that post with Dan, I also have my moments 😄
You can mark this thread as junk 😄
On 21/08/2015 at 09:07, xxxxxxxx wrote:
No problem 🙂
Unfortunately we are out of [JUNK] tags, so it is simply solved.
And I guess, we all have these kind of moments.
