On 19/08/2015 at 06:18, xxxxxxxx wrote:
We are trying to develop a (Tag) plugin to switch camera's from the command line. We thought we had it working since it works when we open a c4d file in the GUI and it switches to the right camera, but when we render on the render farm (command line / nogui) it doesn't work. It gives us:
File "'CommandLine.pyp'", line 31, in Execute AttributeError: 'module' object has no attribute 'argv'
In the log
This is the code:
import c4d import os import sys import getopt
print 'Number of arguments:', len(sys.argv), 'arguments.' print 'Argument List:', str(sys.argv) try: opts, args = getopt.getopt(sys.argv,"c:s:",["camera=","setting="]) except getopt.GetoptError as err: print "Error: Unknown command line options!" print "We only support -c|--camera= -s|--setting=" return False camera = '' setting = '' for opt, arg in opts: if opt in ("-c", "--camera") : camera = arg print "camera = ", camera elif opt in ("-s", "--setting") : setting = arg print "setting = ", setting commandRead = 1 adraw = doc.GetActiveBaseDraw() roots = doc.GetObjects() cameraFound = 0 for obj in roots: if obj.GetName() == camera: adraw.SetSceneCamera(obj) cameraFound = 1 c4d.EventAdd() if cameraFound == 1: camname = adraw.GetSceneCamera(doc).GetName() print "Camera :", camname, "selected" else: print "Camera not Found!"
Is getopt not availble during load? Of are we missing something here? I hope someone can help. We need this for a customer job.
On 20/08/2015 at 02:54, xxxxxxxx wrote:
To get the Cinema 4D command line arguments implement PluginMessage() and filter the C4DPL_COMMANDLINEARGS message. In this message sys.argv holds the command line arguments. You can then store them using a global variable to be used afterwards in your Tag's Execute().
See Command Line Arguments in the Python documentation for a code snippet and more information.
On 20/08/2015 at 14:09, xxxxxxxx wrote:
Thank you very much I'm going to try that.
