How to select Non-Planar Polygons? [SOLVED]
On 07/08/2015 at 01:53, xxxxxxxx wrote:
Hi guys,
I want to select all Non-Planar Polygons like you can do in the attributes>project info(mode)>structure panel. I want to do this with python but cant find anything about this so i'm wondering if this is even possible.
Thanks guys!
On 07/08/2015 at 02:36, xxxxxxxx wrote:
this functionality of the "Project Info" mode cannot be access from the outside so you have to rebuild that functionality.
From a given PolygonObject you can access the polygon selection that is stored in a BaseSelect object with GetPolygonS(). Then you can loop trough all polygons returned by GetAllPolygons(), check if a certain polygon is planar or not and select it.
Best wishes,
Sebastian
On 07/08/2015 at 03:41, xxxxxxxx wrote:
Thanks Sebastian,
I already thought that wasn't possible. :frowning2:
I know how to iterate through the polygons of object and select them. But i don't know how to check if a certain polygon is planar or not. Do i need to do this mathematically?
Greets,
Gianni
On 07/08/2015 at 08:57, xxxxxxxx wrote:
yes, you have to solve this problem mathematically. But since this is a very common task you should be able to find many resource like this one: "Using dot product to determine if point lies on a plane".
Best wishes,
Sebastian
On 10/08/2015 at 01:10, xxxxxxxx wrote:
Thanks Sebastian i have got it working!
found a python script made by pim grooff http://blog.grooff.eu/?p=90
im checking if the cross corner points lines are intersecting if not its a non planar polyGreets,
Gianni
