Release plugins with python? [SOLVED]
On 24/07/2015 at 10:48, xxxxxxxx wrote:
Is it possible to release plugins made with python? I mean, "release" in terms of hiding the source code and let people pay to unlock the full plugin?
Where should I start for all this?
On 25/07/2015 at 02:47, xxxxxxxx wrote:
Sure, I'm doing this right now.
Just encrypt the source into a .pypv file inside C4D.
Check out this post: http://blog.niklasrosenstein.com/2013/08/cinema-4d-r15-important-python-info/
...Yea, I know that a determined hacker can 'listen' to the process and catch the brief instant the original decrypted source is in memory, but you'll never stop everything.
Chris
On 25/07/2015 at 03:33, xxxxxxxx wrote:
Yes, that is right.
About the encryption, it is performed by the "Source Protector..." command, in the Script menu.
I always try to provide .pypv (for releases 15 and 16) and .pype files (for releases pre-15) as there are still many people using older versions.
On 25/07/2015 at 04:43, xxxxxxxx wrote:
Thank you very much
