Check if object is a polygonal parametric object
On 16/07/2015 at 15:27, xxxxxxxx wrote:
I know that obj.GetInfo() & c4d.OBJECT_ISSPLINE will return True if the obj is a spline, no matter if it is a "manual" spline or a parametric spline.
But how can I check if a object is a parametric "polygonal" object?
I mean, how can I check if an object, even if it is a generator, generates a polygonal object?
On 16/07/2015 at 17:49, xxxxxxxx wrote:
Hi
flash idea - op.GetPointCount() ?!or i'm finding solutions that someone make dict with oplist of id's and check out ops from dict
On 16/07/2015 at 18:03, xxxxxxxx wrote:
I want to consider parametric objects as candidates that fulfill the check.
So, a Cube or a Sphere would be considered as "polygonal" objects by my code, even if they start as parametric.
But a Light or a Null would not, because they produce no geometry.
So, the op.GetPointCount() would not work as it only works with really polygonal objects.I guess I will have to create a list with all the IDs and check with something like:
if op.GetType() in ID_list:
Not as elegant and much more complex.
On 16/07/2015 at 18:28, xxxxxxxx wrote:
Hello Rui,
you might need some additional if clauses for PythonGenerators, but basically you can use something like this snippet(in R16- otherwise if op.GetType() == c4d.Opolygon:
if not op: return if op.IsInstanceOf(c4d.Opolygon) : print "polygonalobject" else: base = op.GetCache() if base: if base.IsInstanceOf(c4d.Opolygon) : print "polygonalobject"
Hope this helps?
Best Wishes
Martin
On 17/07/2015 at 01:31, xxxxxxxx wrote:
there are no "polygonal parametric" objects. In Cinema there are generators that fill a cache – possibly with polygon objects. So you would have to check if a given object is a generator and then search the cache for polygon objects.
See also
Best wishes,
Sebastian
On 17/07/2015 at 01:45, xxxxxxxx wrote:
I know there are no "polygonal parametric" objects. It was just a way to differentiate parametric objects that generate geometry from the ones that don't
I will check out that cache thing.
Thank you all.
On 22/10/2015 at 03:59, xxxxxxxx wrote:
Hello
Sorry for necromancy of topic ;)I found additional similar method, ... well known method:
if hasattr(op, 'GetAllPoints') == False: return # or any stuff with procedural
else - possible to csto procedural and return point op
On 22/10/2015 at 06:57, xxxxxxxx wrote:
@Ilya: That would be the same as using op.CheckType(c4d.Opoint). The OP wanted to know whether the
object generates a polygonal object, not if it is a polygonal object. And actually you'd have to test for
c4d.Opolygon and 'GetAllPolygons' , otherwise you'd only check for point objects.-N
Hi
Argh, thank you
i made universal link-gui to op(without ACCEPT flag), i got this method when i looked at console and it wrote about no attribute. Then i remember my battles with pySide, SWIG... expesially attributes for objects and etc.
