On 12/12/2002 at 12:22, xxxxxxxx wrote:
Can somoene produce a node that allows me to access vertex map data, just like point data... ideally it would work almost the same as point data node, as in the index would be the same as the point index, then it would have inputs as follows
Tag (would take the name input from the vertex map tag if you drag and drop i into xpresso) Point (point index), Value (Vertex map value)
and outputs
Value (vertex map value at specific point)
the fields in the attributes manager for this node would be the vertex map name.
This would allow a lot of control over various features such as deformers s wel as with my softbodies thinkingparticles example.
