Connect 2 output ports of xpresso [CLOSED]
  • On 03/07/2015 at 22:08, xxxxxxxx wrote:
    Hello
    I have xpresso setup:
    • root - node, which is xgroup and has 2 output ports
    • new node -  node, which has 1 output port
      I tried to connect them (one output of root and one output of new node) but there is not success.
    I understand that need INPUT + OUTPUT ports, but how can be with 2 outputs by code?
    Manually we can make such connection.
  • On 04/07/2015 at 10:45, xxxxxxxx wrote:
    Again me
    Sample code, execute at any c4d object, problem that ports do not connect (24 pos./line) :
    def main() :
      global vecoutp
      obj = doc.GetActiveObject()
      tag = doc.GetActiveTag()
      if not tag:
          tag = c4d.BaseTag(c4d.Texpresso)
          obj.InsertTag(tag)
      nm = tag.GetNodeMaster()
      xg = nm.GetRoot()
      print "pass 1"
      for i in xrange(xg.GetOutPortCount()) :
          port = xg.GetOutPort(i)
          print port, port.GetName(xg), port.GetMainID()
      bbox = nm.CreateNode(nm.GetRoot(),c4d.ID_OPERATOR_BOX,None, 0, 0)
      nm.InsertFirst(xg, bbox)
      if not xg.GetOutPort(0) :
          vecoutp = xg.AddPort(c4d.GV_PORT_OUTPUT, 536870935)
      c = vecoutp.Connect(bbox.GetOutPort(0)) # <<<<< not connect
      print vecoutp, vecoutp.GetName(xg), vecoutp.GetMainID()
      print bbox.GetOutPort(0), bbox.GetOutPort(0).GetName(bbox), bbox.GetOutPort(0).GetMainID()
      print c
      print "pass 2"
      xg.Redraw()
      nm.Message(c4d.MSG_UPDATE)
    if __name__=='__main__':
  • On 05/07/2015 at 23:31, xxxxxxxx wrote:
    Has python for c4d such limit now? Or possible to do another way?!
  • On 06/07/2015 at 05:09, xxxxxxxx wrote:
    Nodes are laying in same nodemaster
    GvPort.Connect`( _port_ )
     **Note Remember, the nodes of the ports have to be in the same` GvNodeMaster`, otherwise the connection fails.**
    Also i trying to make clone of tag/Nodemaster and do versa - fails
  • On 06/07/2015 at 07:20, xxxxxxxx wrote:
    Hi Ilya,
    I'm afraid, this currently a limitation in Python. As you need to connect two out-ports inside the Xgroup, this does currently not work (same for the input side as well).
    I'm currently checking with development, if there are workarounds.
  • On 06/07/2015 at 07:29, xxxxxxxx wrote:
    Hello Andreas
    Thank you! I will wait.
    I also will test such code with c++ port. Maybe need to port code to CAPI if will be success
  • On 06/07/2015 at 11:26, xxxxxxxx wrote:
    I test this CAPI snippet(write and execute at Remo c4d++ platform)
    There is interesting, it marks ports(arrows) but not show connections
      BaseDocument *doc = GetActiveDocument();
      BaseObject *obj = (BaseObject * ) doc->GetActiveObject();
      if(!obj) return FALSE;
      XPressoTag *xTag = (XPressoTag* )obj->GetTag(Texpresso, 0);
      if(!xTag) return FALSE;
      GvNodeMaster *nm = xTag->GetNodeMaster();
      GvNode *n1 = nm->GetRoot();
      GvPort *p1 = n1->AddPort(GV_PORT_OUTPUT, 536870935, GV_PORT_FLAG_IS_VISIBLE, TRUE);
      GvNode *n2 = nm->CreateNode(nm->GetRoot(), ID_OPERATOR_BOX, NULL, 0, 0);
      GvPort *p2 = n2->GetOutPort(0);
          if (p1 && p2)
          GvNode *n1u = NULL;
          GvNode *n2u = NULL;
          GvPort *p1u = NULL;
          GvPort *p2u = NULL;
          if (nm->IsConnectionValid(n1, p1, n2, p2, n1u, p1u, n2u, p2u))
            n2->AddConnection(n1, p1, n2, p2);
      nm->Message(MSG_UPDATE);
      EventAdd();
    http://oi61.tinypic.com/xmvhbk.jpg
  • On 07/07/2015 at 02:03, xxxxxxxx wrote:
    Ok, found one method, i will make connected samples and store at HD or c4d content.
  • On 08/07/2015 at 01:01, xxxxxxxx wrote:
    Hi
    A few things are not as expected, so i remove flag solved at topic.
    Andreas, any info about to break limit?
  • On 08/07/2015 at 01:34, xxxxxxxx wrote:
    Hi Ilya,
    actually I didn't mark this thread as solved, as I had no answer from the devs. Today it was acknowledged as a limitation. It is currently not possible to connect an output of a node to an output of the parent Xgroup in Python (same for input nodes). Unfortunately there seems to be no workaround. Sorry.
    Regarding your C++ code and the missing connection. I think, you need to call AddConnection() for the other node involved. See this thread.
  • On 08/07/2015 at 02:01, xxxxxxxx wrote:
    Originally posted by xxxxxxxx
    Hi Ilya,
    I add tag to name of topic, thinking it was resolved.
    I don't understand one thing in py-sdk, why need such checking - GvNode.IsGroupNode
    About c++ snippet, i tried different ways and same result.
    Also if it will be (x)group why need this https://developers.maxon.net/docs/Cinema4DCPPSDK/html/group___g_v___g_r_o_u_p.html
  • On 08/07/2015 at 13:05, xxxxxxxx wrote:
    Andreas, you are right!!!
    I did it by c++, i don't know what was wrong. After restarting of machine - it worked! (caches or anything else prevent it)
    i change
    to
    n1->AddConnection(n1, p1, n2, p2);
    i move to c++(maybe S.Rath will bring light to py-code). Solved. Thank you
  • On 09/07/2015 at 05:17, xxxxxxxx wrote:
    Hi Ilya,
    glad it worked in C++.
    The developer feedback I talked about yesterday came from S. Rath. I'm afraid you will have to wait for a fix in C4D for this to work in Python.
  • On 09/07/2015 at 05:35, xxxxxxxx wrote:
    Thanks a'lot.
    R17? or will be sp4 for r16?
    Anyway, please, close topic. I will port stuff to c++
  • On 28/07/2015 at 07:25, xxxxxxxx wrote:
    Sorry that remind
    Have you fixed this issue in 16.051 patch?
    upd.
    🤢 seems not
    it cover several mysterious issue of nvdia 😠
  • On 28/07/2015 at 07:48, xxxxxxxx wrote:
    Hi Ilya,
    you seem to have found out yourself. I would have left a note here, if the SP fixed this bug. Internally this bug has been addressed, but it was to late to get into the 16.051 update.
  • On 28/07/2015 at 07:58, xxxxxxxx wrote:
    Anyway thanks.
    I see that developers back to work from vacation* 😉. If we got fix.
    * - You or someone from team pointed at this fact
  • On 03/11/2015 at 07:48, xxxxxxxx wrote:
    This problem should be fixed in R17.
    Hello
    I forgot about this - i'm checking out of it > that's great - it works! Thanks a'lot 👏👍
    (please, do not brake it)😉
