SelectionChanger example [SOLVED]
  • On 30/06/2015 at 12:09, xxxxxxxx wrote:
    Cinema 4D Version:   R16
    Platform:      Mac OSX  ;
    I need to convert a selection of edges in a multi-selection of objects to points.
    I know I have to create modelingcommanddata for this.
    Here is what I've got so far:
    ModelingCommandData cd;
    cd.doc = doc;
    cd.arr = selection;
    But how do I assign the left, right and tolerance??
    https://developers.maxon.net/docs/Cinema4DCPPSDK/html/group___m_d_a_t_a___c_o_n_v_e_r_t_s_e_l_e_c_t_i_o_n.html
    Left should be edges, right points and tolerance false.
    Thanks in advance for your help and time!
    Greetings,
    Casimir Smets
  • On 30/06/2015 at 14:10, xxxxxxxx wrote:
    I would think that you set the three parameters for the MCOMMAND_CONVERTSELECTION call in a BaseContainer that is attached to the ModelingCommandData bc field.
    BaseContainer bc;
    bc.SetInt32(MDATA_CONVERTSELECTION_LEFT, 1);  // From Edges
    bc.SetInt32(MDATA_CONVERTSELECTION_RIGHT, 0); // To Points
    bc.SetBool(MDATA_CONVERTSELECTION_TOLERANT, false);
    cd.doc = doc;
    cd.arr = selection;
    cd.bc = &bc;
    // Etc.
  • On 01/07/2015 at 01:50, xxxxxxxx wrote:
    Hi Robert!
    Yeah, I thought it to be something like that.
    I've tested the following code, but it doesn't work:
    BaseContainer bc;
    cd.doc = doc;
    cd.arr = selection;
    cd.bc = &bc;
    if (!SendModelingCommand(MCOMMAND_CONVERTSELECTION, cd))
      return false;
    EventAdd();
    I do this inside a CommandData/GeDialog plugin, inside Command of the dialog, when a button is pressed.
    Does somebody have any idea what could be wrong?
    Greetings,
    Casimir Smets
  • On 01/07/2015 at 04:44, xxxxxxxx wrote:
    Hi Casimir,
    you could also check the SelectionChanger class. Maybe it helps.
  • On 01/07/2015 at 05:02, xxxxxxxx wrote:
    Hi Andreas,
    Thanks for your answer!
    That looks like something I could use!
    I will definately look into this :D
    Greetings,
    Casimir Smets
  • On 01/07/2015 at 08:25, xxxxxxxx wrote:
    I have one problem: I can't get the selected points.
    If I try:
    if (!selectionChanger->GetPoints())
      GePrint("The selection changer couldn't get the selected points!");
    the console prints out my GePrint...
    Here is my relevant code:
    AutoAlloc<AtomArray> selection;
    if (!selection) return false;
    Vector globalModelingAxis = doc->GetHelperAxis()->GetMg().off;
    Vector projection = newPosition;
    if (setX == true)
      projection.x = newPosition.x - globalModelingAxis.x;
    if (setY == true)
      projection.y = newPosition.y - globalModelingAxis.y;
    if (setZ == true)
      projection.z = newPosition.z - globalModelingAxis.z;
    AutoAlloc<SelectionChanger> selectionChanger;
    for (Int32 x = 0; x < selection->GetCount(); x++)
       GePrint("Inside the object iteration!");
       PolygonObject *opPoly = static_cast<PolygonObject*>(selection->GetIndex(x));
       if (!opPoly) return false;
       GePrint("Inside the object iteration - first return!");
       BaseSelect *edgeSelection = opPoly->GetEdgeS();
       if (!edgeSelection) return false;
       GePrint("Inside the object iteration - second return!");
       if (!selectionChanger->InitFromSelection(edgeSelection, Medges))
            GePrint("The selection changer didn't initialize!");
            return false;
       else
           GePrint("The selection changer did initialize!");
       if (!selectionChanger->GetPointS())
       BaseSelect *pointSelection = selectionChanger->GetPointS();
       if (!pointSelection) return false;
       GePrint("Inside the object iteration - third return!");
       Vector *points = opPoly->GetPointW();
       if (!points) return false;
       GePrint("Inside the object iteration - END!");
       for (Int32 y = 0; y < opPoly->GetPointCount(); y++)
           if (pointSelection->IsSelected(y))
               GePrint("The point from edge is selected!");
               points[y] = points[y] + projection;
      opPoly->Message(MSG_UPDATE);
    I hope somebody can help!
    With kind regards,
    Casimir Smets
  • On 03/07/2015 at 05:04, xxxxxxxx wrote:
    you forgot to pass the object when initializing the SelectionChanger.
    This:
    has to be:
    if (!selectionChanger->InitFromSelection(edgeSelection, Medges, opPoly))
  • On 03/07/2015 at 06:06, xxxxxxxx wrote:
    Hi Andreas,
    Thanks for your answer! That did the trick!
    You can mark this thread as solved!
    Greetings,
    Casimir Smets
  • On 03/07/2015 at 06:25, xxxxxxxx wrote:
    One last thing, could you please change the name to something like this: SelectionChanger example.
    Thank you very much!
    Greetings,
    Casimir Smets
  • On 03/07/2015 at 06:26, xxxxxxxx wrote:
    Good thought 🙂
