Insert Nulls Sequentially, Problem [SOLVED]
On 25/06/2015 at 02:18, xxxxxxxx wrote:
Hi Community,
i just started with python (i'm a total n00b and no mathematical genius ;)) and i have a logical problem with my script. maybe someone can help me out _<_img src="http://www.c4dcafe.com/ipb/uploads/emoticons/default_smile.gif" border="0" alt=":)" title=":)" /_>_
insert_light **creates a null_object with a light as a child. The null gets named Light.1, Light.2, Light.3...
insert_scene **creates a null_object with a cube as a child. The null gets named Scene.1, Scene.2, Scene.3...the problem with my script is, that insert_light() and insert_scene() create Nulls like
Light.1
Scene.2
Light.3
Scene.4But I want it like
Light.1
Scene.1
Light.2
Scene.2
How can i rename the nulls with the same child sequentially and not all nulls? Can anyone help me with this?
Thanks! Martin
--------------------------------------------------------------------------import c4d
from c4d import gui
#Welcome to the world of Pythondef insert_light() :
doc.InsertObject(c4d.BaseObject(c4d.Onull))
doc.InsertObject(c4d.BaseObject(c4d.Olight))
parent = doc.SearchObject("Null")
child = doc.SearchObject("Light")
child.InsertUnder(parent)
ObjCount = doc.GetObjects()
OTypCount = 0
for i in ObjCount:
if child.GetType() == 5102 and i.GetType() == 5140:
OTypCount = OTypCount + 1
parent.SetName("Light."+ str(OTypCount))
def insert_scene() :
doc.InsertObject(c4d.BaseObject(c4d.Ocube))
child = doc.SearchObject("Cube")
OTypCount = 0
for i in ObjCount:
if child.GetType() == 5159 and i.GetType() == 5140:
parent.SetName("Scene."+ str(OTypCount))
if __name__=='__main__':
insert_light()
insert_scene()
On 25/06/2015 at 03:09, xxxxxxxx wrote:
this is a logic error, in these 2 lines:
if child.GetType() == 5159 and i.GetType() == 5140:you are checking child every time "which is always true" .
On 25/06/2015 at 03:30, xxxxxxxx wrote:
Like this?:
import c4d from c4d import gui #Welcome to the world of Python def insert_lights_and_objects(numberOfLights) : for i in xrange(numberOfLights) : # Create the null and the light. Set the names lightNull = c4d.BaseObject(c4d.Onull) lightNull.SetName("Light." + str(i+1)) lightObj = c4d.BaseObject(c4d.Olight) lightObj.SetName("Light." + str(i+1)) # Insert into scene doc.InsertObject(lightNull) lightObj.InsertUnder(lightNull) # Create the null and the cube. Set names objectNull = c4d.BaseObject(c4d.Onull) objectNull.SetName("Scene." + str(i+1)) cubeObj = c4d.BaseObject(c4d.Ocube) cubeObj.SetName("Scene." + str(i+1)) # Insert into scene doc.InsertObject(objectNull) cubeObj.InsertUnder(objectNull) c4d.EventAdd() if __name__=='__main__': insert_lights_and_objects(5)
On 25/06/2015 at 03:38, xxxxxxxx wrote:
Oops. Didn't see your post Mohamed :)
-b
On 25/06/2015 at 03:50, xxxxxxxx wrote:
Hi Mohamed and bonsak, thanks for your replies!!
@yes, but i don't know how to solve this :)
@bonsak
thanks for your script, but it is not exactly what i want.
everytime your script gets executed, you get the same names according to the given range number.
what i want is that the script checks how many Scene-nulls or Light-nulls are already there in the objectmanager und changes the names of newly created nulls "incrementally" according to the count of nulls of the same "kind". mh, confusing i know ;) just like c4d does it if you create new objects of the same kind
On 25/06/2015 at 08:31, xxxxxxxx wrote:
change this:
to:
if i.GetDown() and i.GetType() == 5140:
if i.GetDown().GetType() == 5102:
On 25/06/2015 at 09:13, xxxxxxxx wrote:
It works!!! Thank you so much :)
