On 22/06/2015 at 09:38, xxxxxxxx wrote:
--------- For my personal projects, I've been using Makefiles for a very long time now (around 2 years) on Windows and Mac to compile my C++ plugins. This was working great but **make **often gave me headache. You can find my makefiles here: https://github.com/NiklasRosenstein/c4dmake
Starting today, I will use my own build system called "Creator" which is a Python based tool and it outputs ninja build files. If you don't know about ninja, I suggest you check it out. It's a very fast build tool, but it requires a meta build software to write the build definitions file, and that is what **Creator **is.
Creator is open source and licensed under the MIT license. You can find it here on GitHub. c4dunit, the scripts to build Cinema 4D plugins, are also on GitHub.
I just wanted to share this with others, maybe it will be useful for some. I have seen some posts in the past about alternative ways to compile Cinema 4D plugins using Makefiles and CMake and I want to throw my method in the pool as well.
Cheers! Niklas
On 23/06/2015 at 12:31, xxxxxxxx wrote:
Interesting. I'll definitely check this out.
-b
On 24/06/2015 at 03:29, xxxxxxxx wrote:
I agree with Bonsak - Looks interesting
On 24/06/2015 at 11:57, xxxxxxxx wrote:
Glad you're finding this interesting. Let me know if you have any questions or problems and please keep in mind that Creator is very young software and will have a lot of bugs.
