Dialog Button executes code of 2 buttons [SOLVED]
On 19/06/2015 at 05:59, xxxxxxxx wrote:
Cinema 4D Version:   R16
Platform:      Mac OSX  ;
I have a commandData plugin working together with a messageData plugin.
I have 2 buttons inside my GUI: DLG_BUTTON_1 and DLG_BUTTON_2.
If you press on them, they both send a GePrint with their value inside ("Pressed button 1/2").
The problem is, if I press the first button, GePrint prints them both.
If I press the second button, GePrint only prints the second line.
Here is my code:
Bool MyDialog::Command(Int32 id, const BaseContainer &msg)
  switch (id)
      case DLG_BUTTON_1:
          BaseDocument *doc = GetActiveDocument();
          Int32 modelMode1 = doc->GetMode();
          if (modelMode1 == Mmodel)
              GePrint("Pressed button 1");
      case DLG_BUTTON_2:
          Int32 modelMode2 = doc->GetMode();
          if (modelMode2 == Mmodel)
              GePrint("Pressed button 2");
  return true
Does somebody know why this is happening?
And if I put code inside the if statement, will that be called 2 times as well?
Thanks in advance for your help and time!
Greetings,
Casimir Smets
On 19/06/2015 at 06:13, xxxxxxxx wrote:
Schoolboy error, you forgot to add the 'break' after each case.
Steve
On 19/06/2015 at 07:03, xxxxxxxx wrote:
Hi Steve,
Hahaha, feeling a little bit stupid now! 😄
I'm glad I've got it working now 😄
Thanks for your answer!
Greetings,
Casimir Smets
