On 18/06/2015 at 09:11, xxxxxxxx wrote:
Hi all,
I want to update my PluginGUI. So I make a chek and then wanna activate one ore the other group in my gui But what is to be done that my MainDialog is updated
Here is my code:
def UpdateLayout(self) : doc = c4d.documents.GetActiveDocument() pree_check = [] pree_check = a_polygon_selektion_tag_is_selected(doc) is_selected = pree_check[0] self.LoadDialogResource(res.DLG_MAIN) if is_selected == True: self.Enable(res.GRP_DEAKTIVATED_REASON, True) print "es ist etwas selektiert" self.RemoveElement(res.GRP_POLYGONS_AUTOMATICLY) else: print "nichts ist selektiert" self.RemoveElement(res.GRP_DEAKTIVATED_REASON) self.Enable(res.GRP_POLYGONS_AUTOMATICLY, True) return True
Thanks a lot
On 19/06/2015 at 06:45, xxxxxxxx wrote:
you can update a group of your dialog layout using LayoutChanged(), typically in combination with LayoutFlushGroup(). You find and extensive dialog example in the C++ GitHub repository.
Best wishes, Sebastian
On 10/07/2015 at 10:09, xxxxxxxx wrote:
Hello Kissling,
was your question answered?
