On 13/06/2015 at 06:29, xxxxxxxx wrote:
Cinema 4D Version: R16.050
Platform: Mac OSX ;
Language(s) : C++ ;
Hi
I can't get the sdk from github to work when its placed at the root of the plugins directory. This is what i do:
1. Download the c++ SDK from github expand the zip archive here:
"/YOUR_R16050_DIR/plugins/cinema4d_cpp_sdk-master"
2. Open the xcode project at "/Applications/Maxon/YOUR_R16050_DIR/plugins/cinema4d_cpp_sdk-master/cinema4dsdk.xcodeproj".
There are 3 files missing:
2 from the configurations folder:
debugbase.xcconfig
releasebase.xcconfig
1 from the libs folder:
cinema.framework.xcodeproj.
3. Select each missing file and read their path in the right column of xcode:
"../../../frameworks/settings/debugbase.xcconfig"
"../../../frameworks/settings/releasebase.xcconfig"
"../../../frameworks/cinema.framework/project/cinema.framework.xcodeproj"
4. So to test if i can reach these files from the sdk folder i open the terminal and cd to "/Applications/Maxon/YOUR_R16050_DIR/plugins/cinema4d_cpp_sdk-master
5. Then try to cd to "../../../frameworks/settings" which is where the xcode project are looking for the two first files:
"no such file or directory" So this must be wrong.
6.Then try to cd to "../../frameworks/settings"(one level lower and then down) :
This gets you here: "/Applications/Maxon/YOUR_R16050_DIR/frameworks/settings" So this is correct.
7. If i replace the missing files with the correct ones, let it index and then select the main.cpp
I get an error on line 25 saying "c4d.h not found"
8. Check the constant "MAXON_ROOTDIR" in the project build settings section:
It is set to "../../../"
This path reolves to "/Applications/Maxon" if you start from "/Applications/Maxon/YOUR_R16050_DIR/plugins/cinema4d_cpp_sdk-master"
For this path to be correct you have to start from inside the: "/Applications/Maxon/YOUR_R16050_DIR/plugins/cinema4d_cpp_sdk-master/cinema4dsdk.xcodeproj" folder
9. Change the "MAXON_ROOTDIR" to "../../" Let it index and select the main.cpp. Same error.
The sdk that comes installed with cinema R16 has the no missing files when placed in the plugins directory, and the MAXON_ROOTDIR is set to "../../" Not "../../../" as in the github version. Could this be the root of the problem?
I have no idea how to get the github version of the sdk to work unless i place it inside a folder inside the plugins folder.
Bonsak
xcode version 6.3.2
