cmd-renderer: Message when project is loaded
On 30/05/2015 at 05:06, xxxxxxxx wrote:
Hi!
There's no CoreMessage() sent to a MessageData plugin and also no PluginMessage() directly after the
project was loaded and before the rendering starts. Is there still a way to intercept? I only want to use
C++ if absolutely necessary (I can imagine implementing a Scene Hook plugin that reacts on the render
notification message).Thanks,
NiklasPS: Output from my test (not a single CoreMessage is sent)
Application start : 05/30/15 at 13:05:44 Executable : 64 Bit Version / Build : 16.050 / RB131856 Debugger : not available Memory model : release Startup path : file:///C:/maxon/Cinema 4D R16 Dev Application path : file:///C:/maxon/Cinema 4D R16 Dev/Commandline.exe Application executable : file:///C:/maxon/Cinema 4D R16 Dev/Commandline.exe Resource path : file:///C:/maxon/Cinema 4D R16 Dev/resource Module path(s) : file:///C:/maxon/Cinema 4D R16 Dev/modules Temporary path : file:///F:/cygwin/tmp Prefs path : file:///C:/Users/niklas/AppData/Roaming/MAXON/Cinema 4D R16 Dev_9E31F8EF Global Prefs path : file:///C:/Users/niklas/AppData/Roaming/MAXON OS version : Windows 7, 64 Bit, Professional Edition Service Pack 1 (build 7601) Processor : 8x Intel Core i7-4770K CPU Computer name : NIKLAS-PC Thread Count : 8 Cpu Speed (MHz) : 3500.000 Application Type : Modular Command line arguments : "-nogui" "-render" "shadertest.c4d" "-oimage" "foo.png" Loading file:///C:/maxon/Cinema 4D R16 Dev/modules/c4dplugin.xdl64 with module(s) net.maxon.c4d.c4dplugin Loading file:///C:/maxon/Cinema 4D R16 Dev/modules/crashhandler.module.xdl64 with module(s) net.maxon.crashhandler Loading file:///C:/maxon/Cinema 4D R16 Dev/modules/crypt.module.xdl64 with module(s) net.maxon.crypt Loading file:///C:/maxon/Cinema 4D R16 Dev/modules/image.module.xdl64 with module(s) net.maxon.image Loading file:///C:/maxon/Cinema 4D R16 Dev/modules/mesh.module.xdl64 with module(s) net.maxon.mesh Loading file:///C:/maxon/Cinema 4D R16 Dev/modules/misc.module.xdl64 with module(s) net.maxon.misc Loading file:///C:/maxon/Cinema 4D R16 Dev/modules/network.module.xdl64 with module(s) net.maxon.network Loading file:///C:/maxon/Cinema 4D R16 Dev/modules/triangulation.module.xdl64 with module(s) net.maxon.triangulation \>>> PluginMessage: 1000 \>>> PluginMessage: 1033567 Vray License Acquired \>>> PluginMessage: 1001188 WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] WARNING: Unknown baselist allocator - RegID: 7 [ge_register.cpp(430)] \>>> PluginMessage: 1033674 \>>> PluginMessage: 1033674 \>>> PluginMessage: 450000215 Loading Project: C:\Users\niklas\Desktop\shadertest.c4d Rendering frame 0 at <Sat May 30 13:05:46 2015> Rendering Phase: Setup Progress: 0% Rendering Phase: Main Render Progress: 0% Rendering Phase: Finalize Rendering successful: 0.093 sec. \>>> PluginMessage: 1002 \>>> PluginMessage: 300002148 \>>> PluginMessage: 1033568 \>>> PluginMessage: 1001 \>>> PluginMessage: 300002146
On 31/05/2015 at 02:58, xxxxxxxx wrote:
Okay, I've worked around this by building an API extension plugin. You can find all information
in this repository: https://github.com/nr-plugins/rendernotif
On 31/05/2015 at 04:43, xxxxxxxx wrote:
Hi Niklas,
thanks for this and the other great stuff at your github repository!
Best wishes
Martin
