On 24/05/2015 at 01:27, xxxxxxxx wrote:
I need to open a dialog with 'DLG_TYPE_MODAL' to prevent the user from making changes while it is open. However, it seems many things don't work with this type: pop-up tooltips, button hover-color changes, and timers are a few.
Is there some way to make a timer work with a 'DLG_TYPE_MODAL' ?
Also, there doesn't seem to be an option with 'DLG_TYPE_ASYNC' to make it not sizable. Is that correct?
Thanks,
Chris
On 25/05/2015 at 03:50, xxxxxxxx wrote:
Hi Chris,
Originally posted by xxxxxxxx I need to open a dialog with 'DLG_TYPE_MODAL' to prevent the user from making changes while it is open. However, it seems many things don't work with this type: pop-up tooltips, button hover-color changes, and timers are a few. Is there some way to make a timer work with a 'DLG_TYPE_MODAL' ?
In which context are you? A script or a plugin?
Originally posted by xxxxxxxx Also, there doesn't seem to be an option with 'DLG_TYPE_ASYNC' to make it not sizable. Is that correct?
Yes there's no way to make an asynchronous dialog not sizable.
On 29/05/2015 at 08:57, xxxxxxxx wrote:
Yannick, It is a Python plugin, and the timer doesn't work with modal.
On 01/06/2015 at 08:09, xxxxxxxx wrote:
Could you post some code? I can't reproduce this behavior.
On 15/12/2016 at 08:02, xxxxxxxx wrote:
I am having some issues getting tooltips to work with modal dialogs as well.
The code for the bitmap button:
bc = c4d.BaseContainer() helpText = "<b>BOLD HEADER</b>\nInfo text here." bc.SetString(c4d.BITMAPBUTTON_TOOLTIP, helpText) dir, file = os.path.split(__file__) ## GET THE PLUGIN DIRECTORY h = os.path.join(dir, "res/icons", "ButtonImage.png") ## GET THE IMAGE LOCATION bc.SetBool(c4d.BITMAPBUTTON_BUTTON, True) bc.SetFilename(BUTTON, h) self.myButton = self.AddCustomGui(BUTTON, c4d.CUSTOMGUI_BITMAPBUTTON, "Bitmap Button", c4d.BFH_CENTER | c4d.BFV_CENTER, 10, 1, bc) self.myButton.SetImage(h)
On 16/12/2016 at 10:15, xxxxxxxx wrote:
Hi Marc,
I confirm tooltips doesn't work inside modal dialogs. I'll check if this is a limitation or a bug.
On 16/12/2016 at 10:17, xxxxxxxx wrote:
Thanks! Would be great if there was a fix or work around :)
