On 21/05/2015 at 12:37, xxxxxxxx wrote:
i got an object with an vertex map tag on it. now ich want to apply a value to a selected point. how?
On 22/05/2015 at 01:24, xxxxxxxx wrote:
this script converts a weight map to a point selection. Hope this helps!
Edit: the other way round could be done by using SetAllHighlevelData("the array with your selection")
Best wishes Martin
import c4d, time from c4d import gui def main() : #validate object and weighttag if not op:return if not op.IsInstanceOf(c4d.Opolygon) :return pwtag = op.GetTag(c4d.Tvertexmap) if not pwtag: return #get weight data weightarray = pwtag.GetAllHighlevelData() #deselect points selPoints = op.GetPointS() selPoints.DeselectAll() pointcount = op.GetPointCount() t = time.time() #Set the PointWeights to Selection for i in xrange(pointcount) : if weightarray[i]>0.5: selPoints.Select(i) t1 = time.time() - t print "converted to selection piece by piece in "+ str(t1) + " sec" c4d.EventAdd() if __name__=='__main__': main()
On 29/05/2015 at 07:45, xxxxxxxx wrote:
Hello Pyr,
was your question answered?
Best wishes, Sebastian
