On 19/05/2015 at 03:19, xxxxxxxx wrote:
User Information: Cinema 4D Version: R16 Platform: Mac OSX ; Language(s) :
--------- Hi,
I'm adding some Xpresso nodes to my objectdata plugin. I have a mathnode and SetParameter(GV_MATH_FUNCTION_ID, GV_MUL_NODE_FUNCTION, DESCFLAGS_SET_0) works perfectly. However, when I try to use SetParameter(GV_DYNAMIC_DATATYPE, GV_INT, DESCFLAGS_SET_0) it does nothing. Even if I change GV_INT to 15 (the corresponding value) it does nothing.
Does anybody know how to fix this? Thanks in advance for your help and time! Greetings, Casimir Smets
On 19/05/2015 at 06:49, xxxxxxxx wrote:
could you provide us some more code so we could reproduce what you are trying to do?
Best wishes, Sebastian
On 19/05/2015 at 07:15, xxxxxxxx wrote:
Here is some more code, inside MSG_DESCRIPTION_COMMAND:
BaseDocument* doc = ((BaseObject* )node)->GetDocument(); if (!doc) return false; BaseObject* op = (BaseObject* )node; if (!op) return false; ModelingCommandData cdFirstObject; cdFirstObject.doc = doc; cdFirstObject.op = op; if (SendModelingCommand(MCOMMAND_CURRENTSTATETOOBJECT, cdFirstObject)) { BaseObject* firstObject = static_cast<BaseObject*>(cdFirstObject.result->GetIndex(0)); doc->InsertObject(firstObject, nullptr, op); if (firstObject) { XPressoTag* myXPressoTag = static_cast<XPressoTag*>(firstObject->MakeTag(Texpresso, NULL)); if (!myXPressoTag) return false; GvNodeMaster* myNodeMaster = myXPressoTag->GetNodeMaster(); if (myNodeMaster) { GvNode* mathNode = myNodeMaster->CreateNode(myNodeMaster->GetRoot(), ID_OPERATOR_MATH); if (!mathNode) return false; mathNode->SetParameter(GV_MATH_FUNCTION_ID, GV_MUL_NODE_FUNCTION, DESCFLAGS_SET_0); // Works perfectly mathNode->SetParameter(GV_DYNAMIC_DATATYPE, GV_INT, DESCFLAGS_SET_0); // Doesn't work, even not if I change GV_INT to 15 } else { return false; } } else { return false; } } EventAdd();
I hope this provides you with enough information. Greetings,
Casimir Smets
On 19/05/2015 at 07:43, xxxxxxxx wrote:
It is definately something weird, in my opinion. I've dragged all the possible data types form the math node inside the console, to check for their int values. Here is what I found: -COLOR 3 -BOOLE 400006001 -INTEGER 15 -REAL 19 -VECTOR 23 -NORMAL 400006005 -MATRIX 25 -TIME 22
However, if I use those values I can NEVER get an integer or boole. I've tried to use the values 0-30 inside SetParameter(GV_DYNAMIC_DATATYPE) and here are my results:
0, 1, 2, 4, 5, 6, 8, 9, 10, 11, 12, 13, 14, 16, 17, 18, 19, 20, 21, 24, 26, 27, 28, 29, 30 and 400006001 all give me REAL as result. 3 gives me a COLOR. 7 gives me an empty cycle, and for the values two link fields, I guess, where you can click a button "Open" and then you can select whatever you want on your hard disk, ... even c4d-files. 15 gives me an application error, so C4D just crashes... 22 gives me TIME. 23 gives me VECTOR. 25 gives me MATRIX. 400006005 gives me NORMAL.
As you can see, this raises a big problem, if you want to add an integer-math node. Thanks in advance for your help and answers! Greetings,
On 19/05/2015 at 09:05, xxxxxxxx wrote:
I cannot confirm any problems using the value of 15 or the appropriate constant ID_GV_DATA_TYPE_INTEGER. Also I have no problems setting the value Boole with ID_GV_DATA_TYPE_BOOL.
Can you reproduce the crash using the value of 15?
best wishes, Sebastian
On 19/05/2015 at 09:20, xxxxxxxx wrote:
I can reproduce it constantly :s The next thing I will do is try to reproduce it in an empty project, to see if I still have the problem there. I will post the result here..
Thanks for your help and time! Greetings, Casimir Smets
On 20/05/2015 at 06:04, xxxxxxxx wrote:
I've tried it inside a new project, and there it works fine. It seems to be failing by code that comes after the setting of the datatype. If I delete that code, my problem is gone. But, now, I'm on to the next problem, setting the second input port value.
I've found a great post about how to set a port value: http://kinug.com/c4d/cpp/help/pages/c4d_graphview/doc_GVData699.html However, if I add the method (GvSetPortGeData) and call it with: GvSetPortGeData(-1, myNode, mySecondInPort, run)); it seems to do nothing. I have also tried this inside my new project, with the same result. Before my call to GvSetPortGeData() I have the following code:
GvPort* mathFirstInPort = mathNode->GetPort(1000); GvPort* mathSecondInPort = mathNode->GetPort(1001); GvRun* run = myNodeMaster->GetRun();
which comes after mathNode->SetParameter(GV_DYNAMIC_DATATYPE, ID_GV_DATA_TYPE_INTEGER, DESCFLAGS_SET_0);
If you need more information, just ask me. Thanks in advance for your help and time! Greetings, Casimir Smets
On 20/05/2015 at 10:00, xxxxxxxx wrote:
could you please post all the relevant code of what you are doing and a precise description of what you want to do?
On 21/05/2015 at 02:02, xxxxxxxx wrote:
What I try to do is simply add a math node, and set the following properties: - The Datatype (Integer) - The Math Function (Multiply) - The second input port value (-1)
Here is my full code (except the resource files).
#include "c4d.h" #include "c4d_symbols.h" #include "omyplugin.h" #include "main.h" #include "c4d_basedocument.h" #include "c4d_graphview.h" #include "gvmath.h" class MyPluginData : public ObjectData { INSTANCEOF(MyPluginData, ObjectData) public: virtual Bool Init(GeListNode* node); virtual Bool Message(GeListNode* node, Int32 type, void* data); static NodeData* Alloc(void) { return NewObjClear(MyPluginData); } }; Bool GvSetPortGeData(const GeData& ge_data, GvNode* node, GvPort* port, GvRun* run) { if (!node || !port || !run) return false; GvPortDescription pd; if (!node->GetPortDescription(port->GetIO(), port->GetMainID(), &pd)) return false; GvDataInfo* info = GvGetWorld()->GetDataTypeInfo(pd.data_id); if (info == nullptr) return false; GvDynamicData data; GvAllocDynamicData(node, data, info); CUSTOMDATATYPEPLUGIN* pl = FindCustomDataTypePlugin(data.info->data_handler->data_id); if (pl == nullptr) return false; if (!CallCustomDataType(pl, ConvertGeDataToGv) (ge_data, data.data, 0)) return false; if (!port->SetData(data.data, data.info->value_handler->value_id, run)) return false; GvFreeDynamicData(data); return true; } Bool MyPluginData::Message(GeListNode* node, Int32 type, void* data) { if (type == MSG_MENUPREPARE) { ((BaseObject* )node)->GetDataInstance()->SetInt32(PRIM_PLANE, PRIM_PLANE_XZ); } else if (type == MSG_DESCRIPTION_COMMAND) { DescriptionCommand* dc = (DescriptionCommand* )data; if (dc->id[0].id == CREATE_CHARACTER) { BaseObject* op = (BaseObject* )node; if (op) { XPressoTag* myXPressoTag = static_cast<XPressoTag*>(op->MakeTag(Texpresso, NULL)); if (!myXPressoTag) return false; GvNodeMaster* myNodeMaster = myXPressoTag->GetNodeMaster(); if (myNodeMaster) { GvNode* mathNode = myNodeMaster->CreateNode(myNodeMaster->GetRoot(), ID_OPERATOR_MATH); if (!mathNode) return false; mathNode->SetParameter(GV_DYNAMIC_DATATYPE, ID_GV_DATA_TYPE_INTEGER, DESCFLAGS_SET_0); mathNode->SetParameter(GV_MATH_FUNCTION_ID, GV_MUL_NODE_FUNCTION, DESCFLAGS_SET_0); GvPort* mathFirstInPort = mathNode->GetPort(1000); GvPort* mathSecondInPort = mathNode->GetPort(1001); GvRun* run = myNodeMaster->GetRun(); if (!GvSetPortGeData(-1, mathNode, mathSecondInPort, run)) return false; } else { return false; } } else { return false; } } } return true; } Bool MyPluginData::Init(GeListNode* node) { BaseObject* op = (BaseObject* )node; BaseContainer* data = op->GetDataInstance(); if (!data) return false; return true; } #define ID_MYPLUGIN 1000008 Bool RegisterMyPlugin(void) { return RegisterObjectPlugin(ID_MYPLUGIN, GeLoadString(IDS_MYPLUGIN), OBJECT_GENERATOR, MyPluginData::Alloc, "omyplugin", nullptr, 0); }
On 21/05/2015 at 07:37, xxxxxxxx wrote:
when you debug your code you see that GetRun() returns a nullptr so GvSetPortGeData() cannot work. GvRun is only available during the calculation of Xpresso, so GvSetPortGeData() can only be used inside a custom Xpresso node while it is calculated.
But it seems using the correct DescID it is possible to simply use SetParamter() :
const DescID id = DescID(DescLevel(GV_MATH_INPUT,DTYPE_SUBCONTAINER,0),DescLevel(1001,DTYPE_LONG,0)); mathNode->SetParameter(id, Int32(-1), DESCFLAGS_SET_0);
On 22/05/2015 at 01:18, xxxxxxxx wrote:
Yes, that works! Thank you very very much for your help and time!
