On 12/05/2015 at 15:42, xxxxxxxx wrote:
t try to kill a tag. Not all tags of a selected type.
I' allready have found the Tag
for tag in taglist: if sel_name != tag[c4d.TEXTURETAG_RESTRICTION]: print "delete" print tag[c4d.TEXTURETAG_RESTRICTION] obj.KillTag(c4d.Ttexture)
But obj.KillTag(c4d.Ttexture) delets all Texture-Tags. I only whant to delete the tag whitch does not match to the sel_name.
Does anybody has an Idea how to delete only one Tag?
Thanks
On 13/05/2015 at 01:38, xxxxxxxx wrote:
Does nobody has an idea??? Maybe it is so f**king easy that nobudy will give me an advice???
Ronald
On 13/05/2015 at 02:04, xxxxxxxx wrote:
actually it should be enough to simply call tag.Remove().
On 13/05/2015 at 02:09, xxxxxxxx wrote:
I'm too, prefer remove Kissling post more code - i'm lazy to add more
a few mods:
import c4d from c4d import gui #Welcome to the world of Python def main() : taglist = doc.GetActiveTags() sel_name = "Polygon Selection.1" for tag in taglist: if sel_name != tag[c4d.TEXTURETAG_RESTRICTION] and tag.GetType() == c4d.Ttexture: print "delete" print tag[c4d.TEXTURETAG_RESTRICTION] tag.Remove() c4d.EventAdd() if __name__=='__main__': main()
On 13/05/2015 at 03:03, xxxxxxxx wrote:
Oh my good
So easy !!!! Thanks a lot Ronald
