Accessing primitive object geometry [SOLVED]
On 12/05/2015 at 01:37, xxxxxxxx wrote:
Cinema 4D Version:   15
Platform:    Mac  ;
Hello folks,
Is there any way to obtain the geometry (faces and vertices) of a primitive object without making it editable?
If I have a primitive object (a cube) and made it editable (right click + "Make Editable") I can get the geometry of that object with these methods:
  const CPolygon* polys = object->GetPolygonR();
  const Vector* vertices = object->GetPointR();
  const Int32 numPolys = object->GetPolygonCount();
  const Int32 numVertices = object->GetPointCount();
They return valid results. I can also see that the type of the object has been changed to OBJECT_POLYGONOBJECT after making it editable.
If I try to access these same values with a primitive object (i.e. a cube) without making it editable I see that the type of the object is OBJECT_GENERATOR but those methods return NULL and 0.
so, does anybody know the correct way to access that information?
On 12/05/2015 at 01:47, xxxxxxxx wrote:
It is simply not possible.
The only way to do that, is to make it editable.
What you could do, is make an object-generator plugin and add the methods yourself (GetPolygonR()), but I don't know if that's what you want.
If you have more questions, just ask.
Greetings,
Casimir Smets
On 12/05/2015 at 02:00, xxxxxxxx wrote:
Thanks for your reply Casimir,
I am not completely sure it is impossible, if you take a look at the X-particles plugin, you can make an emitter that collides with a primitive cube with a collider tag on it, and the cube is not even editable. The only way to simulate this correctly is having access to the object geometry inside X-particles... somehow X-particles is doing it.
cheers.
On 12/05/2015 at 02:14, xxxxxxxx wrote:
I do this inside my plugin and it works fine.  Although my plugin is an ObjectData plugin with the OBJECT_MODIFIER flag..
What i do is just cast the object as a polygonal object and go from there..
So you can use:
ToPoly(op)->GetPolygonR();
or:
static_cast<PolygonObject*>(op)->GetPolygonR();
Something like that..
On 12/05/2015 at 02:17, xxxxxxxx wrote:
Hi Enrique,
You can get the geometry information for a primitive object with BaseObject::GetCache().
Check the type of the returned object and cast it to the appropriate type i.e. PolygonObject in most cases.
On 12/05/2015 at 02:30, xxxxxxxx wrote:
Well, I guess I was wrong, sorry for my bad information!
I didn't think of casting it 😛
Greetings,
Casimir Smets
On 12/05/2015 at 02:41, xxxxxxxx wrote:
Hi Casimir,
Casting the primitive object, does not work. Casting the cache object returned by GetCache() does work.
Hi Casimir,
Am i missing something?  As i said in my post above it works fine for me without using the Cache at all..  But again, that is with an ObjectData OBJECT_MODIFIER plugin..
On 12/05/2015 at 03:14, xxxxxxxx wrote:
Is it an FFD deformer object? You can cast any object to a PointObject if it has a Tpoint Tag on it. Same goes for a PolygonObject if it has a Tpolygon tag on it (and a Tpoint tag).
Hi Enrique,
Thank you very much Yannick, you are absolutely right. It works!
However, now that we talk about deformers, if I have the very same cube deformed, the geometry I get with those methods is the original geometry, not the deformed one. do you know how to get the modified one?
On 12/05/2015 at 04:42, xxxxxxxx wrote:
From GetCache(), scroll down just a little bit and you will find it 😉
Thanks Niklas, I forgot to mention that I was already using that 🙂. I don't know what the problem was at first that it didn't work, but now it is working.
Everything is correctly imported now 🙂
