On 11/05/2015 at 09:04, xxxxxxxx wrote:
I'm trying to automate the setting of the render preferences, but I got stuck at the following. I can't seem to find out how to put the openEXR format to "Lossy 16-Bit float, Zip, in blocks of 16 scan lines"
I found out that you can access the options menu using [c4d.RDATA_SAVEOPTIONS]. But after that i'm at a loss.
I hope someone can help me.
Bas
On 12/05/2015 at 07:39, xxxxxxxx wrote:
Hello and welcome,
the documentation does not contain the information on the proper IDs. To set the format settings you have to acess the RDATA_SAVEOPTIONS BaseContainer and add a new subcontainer with the details:
rd = doc.GetActiveRenderData() container = rd.GetData() # OpenEXR container[c4d.RDATA_FORMAT] = c4d.FILTER_EXR saveOptions = container.GetContainerInstance(c4d.RDATA_SAVEOPTIONS) # OpenEXR options bc = c4d.BaseContainer() bc[0] = 3 # ZIP bc[1] = True # clamp to half float # save OpenEXR options saveOptions.SetContainer(0,bc) # save render data rd.SetData(container) c4d.EventAdd()
best wishes, Sebastian
On 12/05/2015 at 07:55, xxxxxxxx wrote:
That is exactly the thing. Just started learning python, and like you said, I couldn't find the format settings in the documentation.
Thanks a million!
