On 03/05/2015 at 11:52, xxxxxxxx wrote:
I have thess lines of code:
w_variation=C4DNoise(seed) rotw=w_variation.Turbulence(c4d.Vector(step,step_br,0),3,True,overtime+step_br)
and I'm getting the error:
/Users/ruibatista/Second Drive/Development/R15/plugins/Arbor/Arbor.pyp:303: DeprecationWarning: integer argument expected, got float
I just checked the SDK and the only parameter that is required to be integer is the octaves and I'm providing 3, not 3.0 So, what must I do to prevent this error to occur?
On 03/05/2015 at 12:44, xxxxxxxx wrote:
I just read on the last update of the SDK the following: ** C4DNoise.Turbulence(p, rOctaves, bAsolute[, t=0.0])
Generate a turbulence value, this is a sum of multiple noises with different frequency.
Parameters: p (Vector) – Turbulence coordinate rOctaves (float) – The number of octaves. bAbsolute (bool) – True for absolute values. t (float) – The time.
Return type: float Returns: Noise sample. ** So, none of the parameters is required to be integer. So, why am I getting that error?
On 03/05/2015 at 13:41, xxxxxxxx wrote:
The way I found to avoid the error was to explicitly define all parameter names, like this:
rotw=w_variation.Turbulence(p=c4d.Vector(step_br,step,0.0),rOctaves=3.0,bAbsolute=True,lRepeat=1023,t=overtime+step_br)
However, in the SDK, the Turbulence has no lRepeat parameter. Is the SDK wrong?
p.s. I only added the lRepeat parameter because I got an error message stating that it was missing.
On 03/05/2015 at 22:44, xxxxxxxx wrote:
The parameter is indeed missing in the docs. By simply adding "t=overtime+step_br" to your first function call the error should be gone.
