On 26/04/2015 at 17:49, xxxxxxxx wrote:
Simple question. I'd like to create a Python code node inside of an xpresso tag using a separate python script.
I just can't figure out what the Name of the Operator should be...Here is what one would intuitively think it would be called...
node2 = nm.CreateNode(nm.GetRoot(), c4d.ID_OPERATOR_ PYTHON , insert=None, x=200, y=200)
The above command does NOT create the node, obviously because it isn't recognised.
Any idea where I can find some documentation on all the python operators names in the xpool?
Kind regards
On 27/04/2015 at 05:29, xxxxxxxx wrote:
Update: Ok so I have found this list of nodes in the documentation.
https://developers.maxon.net/docs/Cinema4DPythonSDK/help/types/gvnodes.html?highlight=id_operator_formula
There is strangely a COFFEE node, but there does not appear to be a ID_OPERATOR_PYTHON or similar node? Am I missing something?
On 27/04/2015 at 06:41, xxxxxxxx wrote:
the list you discovered lists all of the basic XPRESSO nodes. Additional nodes from modules like MoGraph or Dynamics are not included. Python is a module in Cinema 4D so the ID cannot be found in that list.
You can get the operator ID of any given node with GetOperatorID(). The ID of the Python operator is 1022471; there seems to be no symbol for that.
Best wishes, Sebastian
On 28/04/2015 at 21:12, xxxxxxxx wrote:
Thank you.
