GUI Step not working [SOLVED]
On 21/04/2015 at 12:05, xxxxxxxx wrote:
Cinema 4D Version: R16
Platform: Mac OSX ;
Hi,I'm working on an object-generator plugin, which has some GUI sliders.
As soon as I add the step inside my .res file, I can't use the up-arrow inside Cinema 4D and the step doesn't work. If I delete the step, all works fine.This is my line of code:
REAL LENGTH { UNIT METER; MIN 5.0; STEP 0.5; }
Did anybody have the same problem?
And how can this be fixed?
Thanks for your help and time!Greetings,
Casimir Smets
On 22/04/2015 at 01:48, xxxxxxxx wrote:
Turns out my question was stupid. Inside my Init method I set my sliders.
Previously I did it with data->SetInt32() which I have now replaced with data->SetFloat().
Because an integer doesn't have decimals, my steps can't work. Logic.You can mark this post as solved!
Greetings,Casimir Smets
