On 09/04/2015 at 08:12, xxxxxxxx wrote:
Hi all,
don't know if this is the wright place to ask this: In my scene I have a Coffee-Node witch is doing some things. One of this this is it should activate an object, if a HUD-Element (it's a switch) is activated.
For this I whant to get the Info (something like "klicked=true") if this HUD-Element is klicked with the mouse.
Is it possible to get this Information?
Thanks a lot Ronald
On 10/04/2015 at 06:59, xxxxxxxx wrote:
Hi Ronald,
actually HUD elements are just "visual twins" of actual description parameters. There is no way I know of, to detect if a HUD element get's clicked. But why can't you simply use the original checkbox (the one used to create the HUD) and connect this to your C.O.F.F.E.E. node?
I moved your thread into the "SDK Help" subforum. That's where we handle C.O.F.F.E.E. questions (yeah, I know, that's not logical...).
On 21/04/2015 at 06:59, xxxxxxxx wrote:
Hi Ronald, did you find a solution?
On 21/04/2015 at 07:43, xxxxxxxx wrote:
Yes, I did
It was as easy as it could be: You have to tear the objekt from the Object-Manager only to the Editor! That's it.
Thanks to you Ronald
