Messages between objects [SOLVED]
  • On 13/04/2015 at 09:09, xxxxxxxx wrote:
    Now it is solved,
    the polygonal representation from the parametric object should be taken from current state to object.
    (like Yannick suggested)
    but the dirty state needs to be read from the cache.
    Yannick, thanks!
    Could you please explain why the cache hasn´t been updated ?
    Best wishes
    Martin
    from c4d import utils, gui
    global dirtyCount
    dirtyCount = 0
    def GetLink(op) :
      udOK = False
      for udID, udBC in op.GetUserDataContainer() :
          if udID[1].id==1 and udID[1].dtype==c4d.DTYPE_BASELISTLINK:
              udOK = True
              break
      if not udOK:
          dialog = gui.MessageDialog("No appropriate UserData available! \n"
                                     "Please insert a linkfield \n"
                                     "and activate the generator again.",c4d.GEMB_OK)
          op[c4d.ID_BASEOBJECT_GENERATOR_FLAG] = False
          return None
      link = op[c4d.ID_USERDATA,1]
      if not link:return None
      if link.GetClassification()!=c4d.Obase:
          dialog = gui.MessageDialog("Please insert a valid object in the user data link!",c4d.GEMB_OK)
          return None
      return link
    def GetGeom(op) :
      geom = op
      dirty = op.GetDirty(c4d.DIRTYFLAGS_DATA|c4d.DIRTYFLAGS_MATRIX)
      if not op.IsInstanceOf(c4d.Opolygon) :
          settings = c4d.BaseContainer()
          settings[c4d.MDATA_CURRENTSTATETOOBJECT_NOGENERATE] = False
          settings[c4d.MDATA_CURRENTSTATETOOBJECT_KEEPANIMATION] = True
          settings[c4d.MDATA_CURRENTSTATETOOBJECT_INHERITANCE] = False
          polylist = utils.SendModelingCommand(command= c4d.MCOMMAND_CURRENTSTATETOOBJECT, list= [op.GetClone()], mode =c4d.MODELINGCOMMANDMODE_ALL, bc = settings,  doc= doc)
          if not polylist : return None
          geom = polylist[0]
          if op.GetCache().GetDeformCache() :
              deform = op.GetCache().GetDeformCache()
              dirty = dirty + deform.GetDirty(c4d.DIRTYFLAGS_DATA|c4d.DIRTYFLAGS_MATRIX)
              print dirty, "parametric deform"
      if op.GetDeformCache() :
          deform = geom.GetDeformCache()
          print dirty,"polygonal deform "
          geom = deform
      return geom,dirty
    def main() :
      global dirtyCount
      if op[c4d.OPYTHON_OPTIMIZE] == True:
          dialog=gui.MessageDialog("Please uncheck Optimize Cache! \n"
          return c4d.BaseObject(c4d.Onull)
      link = GetLink(op)
      if not link: return c4d.BaseObject(c4d.Onull)
      geom,dirty = GetGeom(link)
      if not geom: return c4d.BaseObject(c4d.Onull)
      #custom dirty test with linked object
      if dirty != dirtyCount:
          dirtyCount = dirty
          op.SetDirty(c4d.DIRTYFLAGS_DATA|c4d.DIRTYFLAGS_MATRIX)
      if not op.IsDirty(c4d.DIRTYFLAGS_DATA|c4d.DIRTYFLAGS_MATRIX) : return op.GetCache()
      #parent virtual object
      null = c4d.BaseObject(c4d.Onull)
      child = geom.GetClone()
      child.InsertUnder(null)
      return null
  • On 13/04/2015 at 09:32, xxxxxxxx wrote:
    The initial question for this topic has been solved: messaging between the generator and its linked object, more precisely getting the dirty state from the linked object (the original title of the topic isn't event not meaningful).
    Please create a new thread for new questions.
  • On 13/04/2015 at 09:54, xxxxxxxx wrote:
    Feel free to rename this thread to suit the topic, Yannick, no problem.
    That´s all not that meaningful...enjoy your finishing time
    martin
  • On 14/04/2015 at 06:19, xxxxxxxx wrote:
    Hi Martin,
    I'd really like to help you but we need to have an organized forum.
    You can create a new topic with the current script for the Python generator, the issues with it and I'll be happy to help you 🙂.
