On 01/04/2015 at 14:39, xxxxxxxx wrote:
I have the following code:
def Message(self, msg, result) :
if msg.GetLong(c4d.BFM_INPUT_CHANNEL)==c4d.BFM_INPUT_MOUSELEFT:
# the mouse is being pressed
self.dragging=True
mouseX1=msg.GetLong(c4d.BFM_INPUT_X)
mouseY1=msg.GetLong(c4d.BFM_INPUT_Y)
localPos=self.Global2Local()
self.i_x1=mouseX1+localPos['x']
self.i_y1=mouseY1+localPos['y']
while True:
# dragging the mouse
bc = c4d.BaseContainer()
if gui.GetInputState(c4d.BFM_INPUT_MOUSE, c4d.BFM_INPUT_MOUSELEFT, bc) :
if bc.GetLong(c4d.BFM_INPUT_CHANNEL)==c4d.BFM_INPUT_MOUSELEFT:
mouseX2=bc.GetLong(c4d.BFM_INPUT_X)
mouseY2=bc.GetLong(c4d.BFM_INPUT_Y)
self.i_x2=mouseX2+localPos['x']
self.i_y2=mouseY2+localPos['y']
self.Redraw()
if not bc.GetBool(c4d.BFM_INPUT_VALUE) : break
self.dragging=False
return gui.GeUserArea.Message(self, msg, result)
The starting coordinates (stored in i_x1 and i_y1) are calculated correctly.
But the coordinates of the pointer while the mouse button is being pressed (stored in i_x2 and i_y2) are not being calculated correctly. However I'm using the exact same method to calculate both.
If I use Screen2Local instead of Global2Local (in the calculations of the coordinates while the mouse button is being pressed), the i_x2 coordinate is calculated correctly but the i_y2 coordinate has a negative displacement.
Can't they be calculated the same way?
Please, please, please, someone help me.
