On 26/03/2015 at 14:14, xxxxxxxx wrote:
I think there is a big performance issue in the for statement. i want to transfer the color of a noise texture on my clones. this works fine but incredible slow. also if i drag something in the viewport it callculate all the samples again. any suggestions to awoid that? i also has to add a black color vector before the render statment to stop a variable issue with shader_lum
import c4d from c4d.modules import mograph as mo from c4d.modules import render as render from c4d import Vector from c4d.modules.render import ChannelData, InitRenderStruct import random def main() : shader = op[c4d.ID_USERDATA,1] cd = ChannelData() md = mo.GeGetMoData(op) cnt = md.GetCount() tresh = 0.5 coll = md.GetArray(c4d.MODATA_COLOR) uvm = md.GetArray(c4d.MODATA_UVW) visible = md.GetArray(c4d.MODATA_FLAGS) random.seed(666) if md==None: return False #if shader ==None: return False for i in reversed(xrange(0, cnt)) : cd.p = uvm[i] irs = render.InitRenderStruct() shader_lum = Vector(0,0,0) if shader.InitRender(irs) : shader_lum = shader.Sample(cd) shader.FreeRender() coll[i] = shader_lum md.SetArray(c4d.MODATA_FLAGS, visible, True) md.SetArray(c4d.MODATA_COLOR, coll, True) return True
On 26/03/2015 at 16:15, xxxxxxxx wrote:
for every clone you initialize the renderstruct, which is very cost intensive. You can simply initialize and free the renderstruct ouside the for loop, like:
shader.InitRender(render.InitRenderStruct()) for i in reversed(xrange(0, cnt)) : cd.p = uvm[i] shader_lum = Vector(0,0,0) shader_lum = shader.Sample(cd) coll[i] = shader_lum shader.FreeRender()
Best wishes Martin
On 26/03/2015 at 17:48, xxxxxxxx wrote:
works fine but is there a way to stop the calculation of an effector ?
On 27/03/2015 at 01:45, xxxxxxxx wrote:
if any condition is True, return before calculation....
def main() : if op[c4d.ID_USERDATA,2] == True:return
On 27/03/2015 at 08:05, xxxxxxxx wrote:
when you move something in the scene or move the camera the effector has to do his calculations because the result may depend on the position of the object or the camera (as with the "Target" effector). So if you want to disable that, you could just turn the effector off.
Best wishes, Sebastian
On 01/04/2015 at 09:10, xxxxxxxx wrote:
ok - than solved
