On 24/03/2015 at 15:47, xxxxxxxx wrote:
User Information: Cinema 4D Version: R16 Platform: Mac ; Language(s) : C++ ;
--------- I have created a plugin project which references "cinema.framework.xcodeproj" to generate "libcinema.framework.a". With my user account I have read only access to the Cinema 4D "frameworks" folder. When loading my project, Xcode (6.2) always tells me that "cinema.framework.xcodeproj" is locked and if I want to unlock it. Since I don't want to change anything in this project, I always have to answer "Don't unlock". Is there any way to disable that warning and just use the referenced project without unlocking it?
On 25/03/2015 at 15:40, xxxxxxxx wrote:
Hi beba,
In your situation, you're triggering operating system security mechanisms that you can't ignore.
Your only options are:
1. Unlock it so that it stops nagging you about it, and just be careful about not changing anything in it 2. Uninstall the SDK and re-install it to a path where it doesn't lock in the first place 3. Just keep having to answer the question each time
Sorry, but I doubt there are any other options.
Joey Gaspe SDK Support Engineer
On 02/04/2015 at 10:21, xxxxxxxx wrote:
I'll assume the above solved the issue, closing this thread as solved.
