random color on elements in an object
On 11/03/2015 at 00:30, xxxxxxxx wrote:
exp:
http://www.vizpark.com/shop/color-extract-le/
i need an shader which is able to assing random color from an gradient or image like this plugin in max does.
i got an shader which is able to genereate random color per polygon but in this case i got objekts with more faces. so it won't work.
any suggestions ?
edit:
i knew that the shader effektor in combination with an fracture object will do this. but it only works with a few elements.
