On 10/03/2015 at 10:59, xxxxxxxx wrote:
I was wondering if it's possible to grey out res based controller? I have a checkbox in UI, and if it's off, I want certain elements to grey out.
I know it's doable with GeDialog, but what about res based gui?
Thank you.
On 11/03/2015 at 03:40, xxxxxxxx wrote:
Hello Thomas,
ghosting within an object plugin: GetDEnabling
Best wishes Martin
On 11/03/2015 at 07:38, xxxxxxxx wrote:
as Martin said, if a parameter of a NodeData based plugin is enabled or not can be defined with GetDEnabling(). You find some code in the Double Circle example.
Best wishes, Sebastian
On 11/03/2015 at 07:52, xxxxxxxx wrote:
Indeed, thanks Martin for pointing me to right direction.
