Project compile error [SOLVED]
  • On 04/02/2015 at 07:34, xxxxxxxx wrote:
    Cinema 4D Version:   R16
    Platform:      Mac OSX  ;
    I've followed some tutorials (from MAXON and others) and finally could build my cpp plugin.
    The problem is, it raises 2 errors.
    1. Use of undeclared identifier 'gNew'
    2. Unknown type name 'LONG'
    This is my code I copied from a tutorial:
    #define ID_HELLOTEST 1000001        // Unique ID for this plugin
    #include "c4d.h"
    class HelloWorldTest : public CommandData       // Data class for creating new commands (previously known as "menu plugins").
    public:
      virtual Bool Execute(BaseDocument *doc)
          MessageDialog("Hello World");           // Simple popup message.
          GePrint("This is my first cpp plugin"); // Output to C4D's console window.
          return TRUE;
    Bool PluginStart(void)              // The main function C4D calls to begin your plugin (think of it as main).
      return RegisterCommandPlugin(ID_HELLOTEST, "Hello Wolrd", 0, NULL, String("Hello World"), gNew HelloWorldTest);
      // Registers a command plugin with C4D
    void PluginEnd(void)                // Called when the plugin is unloaded from C4D.
    Bool PluginMessage(LONG id, void *data)         // Allows you to receive plugin messages from C4D or other plugins.
      return TRUE;
    Does anybody know what the problem is here?
    Thanks for your help and time!
    Greetings,
    Casimir Smets
  • On 04/02/2015 at 08:07, xxxxxxxx wrote:
    gNew and LONG are depreciated symbol names, please use the current symbol names. See the list of name changes in R15.
    Best wishes,
    Sebastian
  • On 04/02/2015 at 08:15, xxxxxxxx wrote:
    Thanks for your answer, that did it!
    Surely you can close this post now.
    Greetings,
    Casimir Smets
