On 29/01/2015 at 09:00, xxxxxxxx wrote:
User Information: Cinema 4D Version: 13+ Platform: Windows ; Language(s) : C++ ;
--------- I tested this with Cinema 4D R15: 1- create any object 2- add userdata "any type which got sub channels like COLOR"
3- right click this data "user interface -> show sub channels" 4- right click on any sub channel "user interface -> change the gui look (for example from Float to Float slider)" 5- now the BUG appears, you get the chosen GUI for the parent data "which shouldn't happen" , & sub channels values will reset and won't change!!
confirm it, I discovered it by luck when I was playing with the SDK custom data type
On 29/01/2015 at 09:18, xxxxxxxx wrote:
this is the SDK support forum. For bug reports not related to the SDK please use this webpage. Thanks.
Best wishes, Sebastian
